Coil Pack
Old 01-11-2009, 05:16 AM
Don G's Avatar
Coil Pack
hi, i have a '96 3.4l that shows a misfire incyl4. wires good, plugs good, i noticed that cyls 1 and 4 share the same coil pack- is it possible to have a misfire in only one of the cyl from that coil pack? thanks, don.
Old 01-11-2009, 06:59 AM
nc994run's Avatar
Location: raleigh, nc for school chapel hill, nc for home
I have had that issue before and replaced a coil pack that solved the problem. I checked the CEL code multiple times (after doing spark plugs, then again after doing wires) and sometimes it would show a 1 cylinder misfire and sometimes it would show a multi-cylinder misfire, so I would put in a new coil pack and see what happens
Old 01-11-2009, 07:48 AM
97ltd4x4's Avatar
It is possible,although there is a wire that goes to that cylinder as well(will say #1,wires are marked for coil location,NOT wire location)...If you want to find out swap out coils...If miss moves,you have a coil going..if not..chances are its that wire...This is to assume that the plug is good on that cylinder.
Old 01-11-2009, 03:18 PM
Don G's Avatar
put in new wires just in case, plug looks good (20,000 densos), ran good for a few minutes then roughness again. drove 10 miles stopped. ran good for a few when i started it. can coil cause this- i'll swap coils tomorrow to see if code moves...
Old 01-11-2009, 06:19 PM
Staff
DeathCougar's Avatar
Yes, a coil failing can cause this.
Old 01-11-2009, 06:22 PM
darksoldier313's Avatar
know ne one with a vantage or a scope?? easy way to tell
Old 01-12-2009, 08:04 AM
Don G's Avatar
swapped coil packs, misfire stayed the same- cyl#4. next stop injector??
Old 01-12-2009, 09:57 AM
hross14's Avatar
when i sent my injectors out for cleaning at 165k there were some that were in poor shape and others were moderate.
but a misfire--if it were me--(just to rule out stuffs or if it is time for changing)-- i would sweep the major sensors and scope it.
Old 01-12-2009, 10:32 AM
chad1041's Avatar
i have this same problem new coil wires and plugs i have checked everything but the injector will check tommorow a little bit harder on mine (6th cylinder lol ) good luck ill let you know what i find out
Old 01-15-2009, 12:21 PM
Don G's Avatar
#4 injector it was. thanks for the help guys!
justdifferentials
Just Differentials
06-13-2022 07:40 PM
the_supernerd
10-01-2015 09:20 PM
JookUpVandetti
09-17-2015 09:25 PM
mojo4x420
09-16-2015 08:07 AM
Quick Reply: Coil Pack
