Coil Over Question
Coil Over Question
Does anyone know if a Tundra (fab tech) coil over will work on a 99 limited 4Runner. I guess the real question is: Is the 3 bolt location Pattern on the upper A arm the same? If the bolt pattern are the same, I believe the valving would be just right with a TJM and warn stuck on the front.. A little help would be appreciated
Which Fabtech coilover, the Basic or the Performance? If its the Basic, it shouldn't matter because I believe it comes un-assembled and you would use your stock top plate to put the coilover together. I am not sure on the Performance Coilover. I would try to contact a retailer and ask, maybe you could get the Tundra valving with the Tacoma/4Runner topplate (isn't this what they do with the SAW's? Or is the top plate drilled for both app's?).
Originally Posted by Dr. Zhivago
On the SAW's the top plate is drilled for both applications. I'm not sure about the Fabtech pieces.
G
G
the1998sr5
15
07-14-2020 08:35 PM
