Code 42, vehicle speed sensor?
Old 01-20-2005, 05:23 AM
Bumpin' Yota's Avatar
Where the hell is this thing located at? On our chevy with the 4L80e it'd be at the tranny's tail housing, but what about on my auto yota with the 3vze?
Old 01-20-2005, 02:14 PM
TTT - any ideas?
Old 01-20-2005, 03:03 PM
soupkitchen10's Avatar
It should be on top the trans. About in the middle... the ABS speed sensor is on the rear diff.
Old 01-20-2005, 03:14 PM
uh oh....
so to change it or to check it requires that I pull the tranny?
Old 01-20-2005, 09:33 PM
ttt - so changing/checking it is going to be a huge PITA?
Old 01-20-2005, 09:45 PM
WATRD's Avatar
VEHICLE SPEED SENSOR
ON–VEHICLE REPAIR
1. DISCONNECT NO.1 VEHICLE SPEED SENSOR CONNECTOR
2. REMOVE NO.1 VEHICLE SPEED SENSOR ASSEMBLY
(a) Remove the bolt and No.1 vehicle speed sensor assembly.
(b) Remove the speedometer driven gear and O–ring from
the No.1 vehicle speed sensor.
3. INSTALL NO.1 VEHICLE SPEED SENSOR ASSEMBLY
(a) Coat a new O–ring with ATF.
(b) Install the O–ring and speedometer driven gear to the
(c) Install the No.1 vehicle speed sensor to the extension
housing and torque the bolt.
Torque: 16 N·m (160 kgf·cm, 12 ft·lbf)
4. CONNECT NO.1 VEHICLE SPEED SENSOR CONNECTOR
5. DISCONNECT NO.2 VEHICLE SPEED SENSOR CONNECTOR
6. REMOVE NO.2 VEHICLE SPEED SENSOR
(a) Remove the bolt and No.2 vehicle speed sensor.
(b) Remove the O–ring from the No.2 vehicle speed sensor.
7. INSTALL NO.2 VEHICLE SPEED SENSOR
(a) Coat a new O–ring with ATF and install it to the No.2 vehicle
speed sensor.
(b) Install the No.2 vehicle speed sensor and torque the bolt.
Torque: 5.4 N·m (55 kgf·cm, 48 in.·lbf)
8. CONNECT NO.2 VEHICLE SPEED SENSOR CONNECTOR
Old 01-20-2005, 09:48 PM
WATRD's Avatar
Or, depending upon which auto tranny you have.
ON–VEHICLE REPAIR
1. DISCONNECT VEHICLE SPEED SENSOR CONNECTOR
2. REMOVE VEHICLE SPEED SENSOR ASSEMBLY
(a) Remove the bolt and the vehicle speed sensor assembly.
(b) Remove the clip and the driven gear from the vehicle
speed sensor.
(c) Remove the O–ring from the vehicle speed sensor.
3. INSTALL VEHICLE SPEED SENSOR ASSEMBLY
(a) Coat a new O–ring with ATF and install it to the vehicle
speed sensor.
(b) Install the driven gear and the clip to the vehicle speed
sensor.
(c) Install the vehicle speed sensor assembly with the bolt.
4. CONNECT VEHICLE SPEED SENSOR CONNECTOR
Either way, it doesn't say anything about dropping the tranny.
Old 01-21-2005, 06:23 AM
ballerpn0y12's Avatar
is this a difficult procedure to do?
Old 01-21-2005, 07:20 AM
WATRD's Avatar
I have never done it. But, looking at the instructions, I would say no and would allocate about 30 minutes.
Old 01-24-2005, 08:46 PM
WATRD -
Thanks for the procedure on that, I do appreciate it! I guess that makes it easier in that I just need to track down where the speedo cable jumps into the tranny, be it the tail end of it on the TC or the middle top of the tranny....
smthwsn357
12-04-2023 02:08 AM
Seattle_Sign_Guy
07-12-2015 12:38 PM
smiley52
07-11-2015 05:16 AM
wilbertd
07-06-2015 07:39 AM
karbin
07-05-2015 11:37 PM
Quick Reply: Code 42, vehicle speed sensor?
