| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Clutch Problem
__________________
96 tacoma ext. cab K&N cold air intake Flowmaster super 40 3" toytech lift and pro comp aal 2" RB body lift "Eh no fo get lock da hubs ah!" |
#2 (permalink) |
Don't know for sure but for what its worth on another car of mine the slave cyllinder leaked so bad that I did not have enough fluid in the clutch to even get it to work, however even with no fluid the pedal came back fine, there just wasn't anybody home when you pushed down on it.
__________________
99' 4Runner SR5 5spd 3.4L Sonoran Steel 7.1/7.2/OME891 Previous Vehicles: 1985 4x4, 1990 4Runner |
#3 (permalink) |
Did you replace the master or the slave cyl.?
#4 (permalink) |
Staff
have you checked your pedal assy to make sure its not cracked/broken? This is a very common problem with 5sp trucks.
__________________
Tacoma miniheader install kit Now available! Click here for ordering information Need that hard to find part? Nix99 Used Toyota and Lexus parts! |
#5 (permalink) |
Didn't replace any sinse I bought it and Ill take a look at the pedal assy tomorrow. How would I bleed the system though?
__________________
#6 (permalink) |
If your pedal is not broken, this is your master cylinder crapiing out, but ust to be sure bleed your clutch. It's very simple.
#7 (permalink) |
Staff
to bleed the system: have a buddy help you. Pump the pedal 5 times, and hold it. have your buddy open the valve at the slave for 2-3 secs, then close it. Then you let off the pedal. Repeat until pedal firms up properly.
__________________
#8 (permalink) |
Thanks for the advice and info will look into a new master cylinder.
__________________
#9 (permalink) |
ducaria,
Mine is doing the exact same thing. Kinda freaked me out for a second because it makes the clutch grab super low. My pedal moans and squeeks real bad. I am first going to try and service the pedal assymbley. I'd be curious to see what you find also. |
#10 (permalink) |
I had the same problem on my 02.
the master was going bad along with the small bushings in the pedal.
__________________
TRD Supercharger,TRD 7th injector,URD AIC ,Headers,2.5 Magnaflow exhaust,Airfilter,air box mod,flexalite 210 fans,optima yellow top,Warbro 190 ,TRD t stat,ramsey 8000 winch and rear locker mod |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Problem with clutch/clutch pedal | bpina4813 | 86-95 Trucks & 4Runners | 8 | 01-12-2007 08:38 PM |
| clutch problem | halibut | 86-95 Trucks & 4Runners | 1 | 04-22-2006 01:00 AM |
| Clutch pedal/clutch problem: help needed | p.m.coupe | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 03-04-2006 02:18 PM |
| Need help Clutch Problem | jerbear | Maintenance & Repair Archives | 9 | 09-11-2005 08:50 AM |
