Clutch pedal/clutch problem: help needed - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-01-2006, 02:01 PM   #1 (permalink)
I recently bought a 96' V6 Tacoma Extra cab, the VZ or something similar motor. Well here is the problem; this morning Im riding around the parking lot looking for a space to park, while sitting for a few seconds I notice my clutch pedal starts to feel weak and spongy. After a few more depressions the pedal goes to the floor with hardly any engagement. Later on today I go back to the truck after class, check for leaks, check reservoir level and everything looks good. I get in the truck and drive across town and everything is working smoothly until I sit at a stoplight for a few minutes.
If anyone can give me any insight into how to fix this problem or what the cause may be, please do so.
Thanks in advance, Ronnie
p.m.coupe is offline
Old 03-01-2006, 02:21 PM   #2 (permalink)
Jackpot2's Avatar
Sounds like either a master cylinder or slave cylinder problem, slave is cheaper of the two to fix, although you might start by simply bleeding the system at the slave end and purge all the air out. If this doesnt help, then buy a new slave, failing that, buy a master, failing that ....
__________________
Jim, '91 Hilux Surf, wood effect seat
Jackpot2 is offline
Old 03-01-2006, 03:49 PM   #3 (permalink)
MTL_4runner's Avatar
Send a message via AIM to MTL_4runner
Quote:
A sinking clutch pedal with no leaks (at the slave) is probably the master rather than the slave cylinder. I'd bleed first (starting at the slave then the master) then check movement of the slave cyl (helps to have 2 people). If the slave moves fine, then drive for a few days. If the pedal still sinks, replace the clutch master cylinder.
__________________
- Jamie
1996 4Runner SR5 4X4 Auto
Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift
Best OBD II scan tool I have used!.
.....and I am AMERICAN!
MTL_4runner is offline
Old 03-02-2006, 10:10 AM   #4 (permalink)
clutch problem
Thanks for the input...
Old 03-04-2006, 02:18 PM   #5 (permalink)
Jackpot2's Avatar
This might help if you're lost...
http://www.hiluxsurf.co.uk/php_lib/d...ile.php?uid=51
__________________
Jackpot2 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Problem with clutch/clutch pedal bpina4813 86-95 Trucks & 4Runners 8 01-12-2007 08:38 PM
Clutch grinding, poor shifting, cracked clutch pedal bracket T100NewMexico 93-98 T100s 10 09-22-2006 01:31 PM
Will the height adjustment of the clutch pedal affect the wear of the clutch? YotaJunky Maintenance & Repair Archives 6 11-21-2005 08:03 PM
Clutch pedal return problem io Maintenance & Repair Archives 3 07-09-2005 01:52 PM
2009 InternetBrands, Inc.
