Clutch Issues...Not What You Think
Old 06-12-2010, 08:09 PM
PismoJoe's Avatar
Hey everyone, I need some help diagnosing a clutch issue that I am having with my 2002 Tacoma, 3rz, w59 trans. Done some researching for a while with no avail....
Heres the deal....
Randomly (but commonly) my truck refuses to go into gear. ANY gear. And I have never owned a car that is an auto, so it's not in my driving ability.
At startup, if you push the clutch in prior to starting, and hold it down, I can run through all gears with no resistance whatsoever. BUT let off the clutch and try it again (the truck is running now) it will throw a fit. Then randomly, it will allow me to put it into gear
1. Brand new clutch release cyl
2. Bled the whole system and refilled (obviously for the new slave)
3. New trans gear oil (Mobil1 Fully Synthetic GL-5 75w-90)
4. Clutch pedal bracket is not bent
5. Firewall where clutch master sits is not dented/bent/creased
6. Clutch master cyl looks brand new, no leaks
Here are my real questions
A. If its in the hydraulic system (i.e. clutch pedal not adjusted properly) why does it only do it sometimes?
B. If it only does it sometimes, could this be a pressure plate issue?
C. How do you tell a clutch pressure plate issue apart from another clutch related issue?
I'm going nuts over this issue, I feel like I have checked everything and my truck is still a PITA to get into gear
Old 06-12-2010, 08:32 PM
totally a bro
Staff
vital22re's Avatar
sycro's worn? Maybe pull the tranny and check for clutch pressure plate fualts?
Old 06-12-2010, 08:39 PM
PismoJoe's Avatar
That's what I was initially thinking, but if the syncros were worn, wouldn't it do it all the time? I can shift perfectly sometimes....you know when the moon and the sun line up lol not often but it happens
I'm thinking more and more that its pressure plate related....original clutch, but it still grips fine so I really don't want to dig into it...Never really heard of a pressure plate wearing before a clutch disk but I haven't seen alot of things either....Thanks for the ideas though!
Old 06-12-2010, 08:42 PM
totally a bro
Staff
vital22re's Avatar
what about the shifter bushing. Seems to fit better i think for your symptoms
Old 06-12-2010, 08:44 PM
PismoJoe's Avatar
wow maybe I'm thinking too hard about this lol
GREAT call! Will pull the shifter tomorrow and post some good old porn pics if you know what I mean....
Old 06-12-2010, 08:45 PM
totally a bro
Staff
vital22re's Avatar
Truck porn!!! nice!
Old 06-14-2010, 06:09 PM
PismoJoe's Avatar
Alright vital...sadly I do not think that was the culprit. There were no grooves or visible wear on the bushing, it actually looked pretty damn perfect with 130k on it lol
I've noticed that if I match up RPM's, shifting is much easier. Like if I'm pulling up to a stop sign and throw it from 2nd to 1st right before I stop, its like butter. Then again, for no reason it shifts perfect sometimes....
I checked the pedal height and it all seems to be ok...Man this is frustrating
Old 06-15-2010, 04:16 PM
PismoJoe's Avatar
any ideas? I'm leaning towards pressure plate, but has anyone seen a pressure plate fail before a clutch disk?
Old 06-15-2010, 05:50 PM
stepside trd's Avatar
This might have nothing to do with it, but just to think outside the box, did you ever noticed if it happens when the truck is at a certain temp., say, when the trans. is hot, or early mornings on a cold start, etc......
Old 06-15-2010, 05:55 PM
PismoJoe's Avatar
Hot or cold, it doesn't matter. I have noticed that on a moderate to steep downhill slope it is especially hard to get it into gear...
And thanks for the response! I'll take all the ideas I can get, like I said I'm stumped and I have replaced a lot of clutches, but never came across an issue quite like this
Old 06-15-2010, 11:59 PM
wyoming9's Avatar
Red face
I am thinking maybe for some reason the throwout bearing fork area. Something in this area bent broke or what ever causing the release bearing to not move like it should.
Other then it won`t go in gear. You don`t say but I would think If you attempt to put it in gear . It would be like trying to shift from a stop without any clutch.
When It works it all lines up and does what it should.
when you are moving and blip the throttle it more ore less gets every thing moving the same speed so it almost falls right into gear..
You don`t say anything about it popping out of gear while driving .
Like most Transmission and clutch problems you never know till you take it all apart.
Good luck
Old 06-16-2010, 12:10 AM
totally a bro
Staff
vital22re's Avatar
yeah by bushing, i'm talking about where the shifter handle sits in the plate that you pulled off. I'm leaning towards syncro's if the bushing is still intact.
Old 06-16-2010, 10:57 AM
PismoJoe's Avatar
Ohhh gotcha yes I checked that one as well, it looked really good, and the spring was fine too. Ugh I thought we would have nailed it for sure!
I would agree with the syncros, but sometimes it shifts perfect, which is making me lean towards a clutch issue. I mean, if it is the syncros, I might as well just bend over ha I don't have the $$ to rebuild a tranny.
If my clutch was slipping I would be down to get my on and pull her apart...
Either way its not looking very good. Syncros or clutch issue I guess
Old 06-16-2010, 11:10 AM
PismoJoe's Avatar
wyoming, nope it doesn't pop out of gear, and when i try to rev the engine to match up tranny/engine rotation, it doesn't make it any easier to shift.
Old 06-20-2010, 08:00 AM
wyoming9's Avatar
Red face
I know there are different length rods used on the clutch slave cylinder as the clutch wore it no longer would do it`s job but once in a while.
Please let us know what you do find. Just when did it start doing this??
Good luck
Old 06-22-2010, 12:18 PM
PismoJoe's Avatar
Yeah I replaced the clutch slave with the correct one though.
I can't go into any gear, so its not the tranny, and sometimes it shifts fine
Clutch pedal height/freeplay is perfect
New Slave, good master, no air in system
Good shifter bushings and retainer spring
So I guess that leaves the pressure plate I have heard that they can wear out before the disk, just never seen it firsthand like this. As soon as I finish my 4runner I'm going to do the clutch
Old 06-22-2010, 12:38 PM
snobdds's Avatar
I believe it is syncro's related too. I am pretty sure the transmission can be ran on GL-5 gear oil, but it's too slippery for the syncro's to engage properly. Toyota transmissions like GL-4 gear oil. It might be as simple as that...
Old 06-22-2010, 12:48 PM
PismoJoe's Avatar
I would agree but I can't engage in any gear at random times. 1 2 3 4 5 R
If I only lost being able to engage in 1st or 2nd, then syncros would be more likely.
I had GL-4 in the first place, I switched to GL-5 to see if there was a difference but did not notice one. The GL-4 coming out was only about 20k old as well, so it was fairly fresh.
Old 06-22-2010, 12:50 PM
CitrusTheDragon's Avatar
I had a similar problem after I did my clutch and it was because the fork had slipped off the throwout bearing, I didn't discover it till after I burned out the new clutch. Some times it worked other times I had to push hard to get any shift out of it
Old 06-22-2010, 12:52 PM
PismoJoe's Avatar
Yeah I would definitely notice if it was the clutch fork ha it shifts perfectly when I'm moving, its just a PITA to get into gear sometimes/most of the time coming off of a dead stop.
Quick Reply: Clutch Issues...Not What You Think
