| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Clutch Hydraulic System, NEED HELP...
__________________
Choopster 1998 TRD 4Runner TRD Supercharged K&N cold air induction system ARB front bumper w/winch ARB underhood air compressor Sonoral Steel 2nd generation rear bumper JAOS Battle Z suspension w/Old man Emu shocks JAOS side bars Borla SS exhaust Custom rear under carriage storage box Alpin sound system w/Sirius Garmin GPS "Life is short, make a difference" |
#2 (permalink) |
Staff
Sounds like the master cylinder to me. Have you looked to see if it is leaking? Is it losing any fluid?
The master cylinder can bypass without operating or leaking as well. I would look into that.
__________________
Tacoma miniheader install kit Now available! Click here for ordering information Need that hard to find part? Nix99 Used Toyota and Lexus parts! |
#3 (permalink) |
No fluid leaking anywhere. I am just very puzzled as to why a new slave has so exagerated my problem. Thanks...
__________________
#4 (permalink) |
The new slave had more back pressure than the old one, thus the final straw.
I am confused.....you pull the pedal off the floor?? Does your clutch pedal spring not work? I don`t have a standard so I am lost.
__________________
KdF In Memory of my Only Son Chris 99 Taco Prerunner Full OME Suspension Replacement Poly Bushings (all) replacement Greasable shackles |
#5 (permalink) |
I had the clutch pedal to the floor problem on my 88. Replaced the slave cylinder...no dice. Replaced the master cylinder, good to go. (actually I rebuilt the master)
__________________
88 4Runner. 350 V8, R150 5-speed. SAS, 36" TSL's, elocker rear |
#6 (permalink) |
Thanks for the feedback guys. I think my clutch pedal spring is fine, it seems to require fluid pressure for it to return to the top position. I am going to purchase a master cylinder tomorrow and cross my fingers.
__________________
#7 (permalink) |
yea weather you have a good spring or not wont make a difference, if there is a leak in the hydraulic lines the pedal will litteraly get sucked down to the floor when you start to press it. It will do this if the slave cylinder or the master cylinder has a bad seal or if the bleeder valve is left open. In your case i bet its the master cylinder, they seem to fail much more often.
__________________
04 taco, 3.4 5spd. loads of goodies, FZJ80 axle SAS in progress. 85 pickup, 327sbc, truggy, in progress. 86 mazda b2000 street queen haha. 92 mazda B2600i 4x4 absolutely mobs. 81 ford bronco drinks gas 90 mazda mx-5 all original. when in doubt, tach it out. |
#8 (permalink) |
FYI i had no leaks anywhere in the system when mine failed
__________________
#9 (permalink) |
What symptoms where you having and on which runner?
__________________
2000 Toyota 4Runner SR5 Highlander Sport Edition 4x4 3.4L 5 Speed Bilstein Shocks 1999 Tallest Springs |
#10 (permalink) |
Hi,
I have replaced the master cylinder and my problem is fixed. Thanks for the feedback...
__________________
#11 (permalink) |
Staff
I win at teh internets and teh Toyota.
Bow down puny mortals! lol jk
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Hydraulic clutch feels like a cable clutch | tortis | 86-95 Trucks & 4Runners | 6 | 11-29-2007 09:19 PM |
| will small amount of air work itself out of clutch system | pete f | 86-95 Trucks & 4Runners | 7 | 04-15-2007 07:43 AM |
| Help! 2005 4Runner Hydraulic Strut System | kevinhasley | 03+ 4Runner/GX470, & 05+ Tacomas | 23 | 03-23-2005 10:38 PM |
| Hydraulic Clutch Question | cthagreekgod | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 02-05-2005 04:32 PM |
| hydraulic clutch help | dragoneddy | Maintenance & Repair Archives | 2 | 04-30-2004 10:22 PM |
