clutch button problem
Old 06-26-2004, 07:10 PM
Chapman88SR5's Avatar
hey u know the button u push before u start the truck? well my runner starts without pushing that button. why is that? its a 87 4runner
Old 06-26-2004, 07:23 PM
terky's Avatar
well my 82 pickup doesnt have a button, and it starts anyways. Its cool sometimes, like when im doing something with it and dont want to jump all the way in to push the clutch.
Old 06-26-2004, 09:27 PM
884runner's Avatar
the button is a clutch start cancil button. Your runner is supposed to start without it just by pushing the clutch in like a normal stick. The button allows you to start your rig with out using the clutch. Just hold the button down as you turn your rig on. Make sure it's out of gear though.
Old 06-27-2004, 07:52 AM
Flamedx4's Avatar
ACtually you don't have to hold the button while you start. Turn on the key, punch the button once, and it will allow one start without depressing the clutch. (Even after a few minutes I've noticed.) Once the key is cycled through the start position the clutch switch is cancelled. This is a great feature on a tough trail where you killed it (Like on a STEEEEP hill) and need to get moving again but don't have 3 feet for the 3 pedals. Also came in handy once when something in my clutch broke and I had to drive to work for 3 days without using the clutch. Hell on the starter, but worked great.
Old 06-27-2004, 12:34 PM
cabbage's Avatar
There is a button above your clutch pedal that senses if your clutch is depressed or not, it could be off, crawl under and adjust the button by turning it. My button was way too far back, so even with the clutch pressed all the way, I still couldnt start my truck without pressing on the clutch cancel switch, I believe your situation is the exact opposite.
Liadrin
04-25-2022 02:54 PM
jasonty
41
12-23-2018 01:00 PM
Liadrin
09-01-2015 06:44 AM
PlayAwhile
07-20-2015 11:36 AM
rushw
07-18-2015 01:46 PM
Quick Reply: clutch button problem
