Clutch advice, opinions
I need to replace my clutch. Typically I would go factory toyota, but I am not impressed by the new design. They changed the spring dampeners in the disc. It now has plastic retainers. I installed one in my brothers 99 taco and it is clunky and noisy. Its the same design that the 6 spd 4.0 tacos use. I've also seen them fail in the new tacos and FJs. So what are the best aftermarket discs? My truck is an 89 4runner with a s/c 3.4. I was thinking ACT but they are very pricey...
I just replaced my clutch on my 98 4runner actually. I went with a LCE HD clutch and the whole deal was 324 bucks if I remember right. After I pulled my head out of my arse and did the rear seal correctly I am VERY pleased with the clutch. Similar feel to stock but much better grip.
I have been using an ACT clutch with the street performance disk for the past three years with no trouble... sort of... The clutch does not slip (on the street anyway) but I need to push the clutch peddle almost through the firewall to get it to disengage. I am not sure if it is a clutch or flywheel problem but something is wrong and I am getting tired of replacing the clutch master cylinder (it goes bad 2x a year due to the stress to get the clutch to disengage).
Before the ACT with street perf/disk, I ran a 6puck ACT. That clutch worked perfectly except it was a little noisy during take off so after 45K miles, I installed the street performance disk.
I just ordered another ACT 6puck race clutch. This time I am going with the sprung version in hopes it will not make the noise my solid disk made.
Before using the ACT clutch.. I could not find anything that would hold the added power the Supercharger makes...(including a Centerforce Dual Friction).
Good luck.
Jeff
Before the ACT street disk
I am going through the same struggle... which clutch to get. Is the year of your 4Runner correct in the OP (89 or is it a 98?)
I have used Centerforce in my street rods, customs and my truck. Never had any problems. The instructions and documentation is excellent, quality is outstanding and they perform.
Ordered a clutch from marlin crawler today. Hope to have it installed this weekend! Anyone need the throw out bearing or the pilot bearing? I have no use for them and they wouldn't sell me a kit without them for less $. Brand new.
Installed the clutch from marlin crawler today. Pedal feel is lighter than I expected which is nice. Still breaking it in but I'm sure it will be fine. I am definitely impressed with the clutch disc. It is nearly identical to the old style factory clutch, which is exactly what I was looking for
Good deal... keep us posted how it works out !
Jeff
Jeff
Iceman4193
08-28-2015 08:43 PM
matrad
08-08-2015 03:00 PM
britishdudes2dr
07-25-2015 06:47 AM
