Clutch on a 2WD question
About to do my clutch and I have noticed that the crossmember cannot be removed on my model (97 2WD). Has anyone done a clutch on this type of truck. Can you just back out the tranny from the engine and leave it up on top of the crossmember to change the clutch or do you HAVE to turn it 90 degrees and drop it completely forward?
Thanks for the advice
So you don't have to turn it 90 degrees before you drop it down like the service manual says? Do you think there would be enough room to just pull it back and keep it jacked up there so I can get in and replace everything?
the1998sr5
15
07-14-2020 08:35 PM
