clunk and bang turning left
We have a '92 Toyota SR5 4x4 pickup with V6 engine - stock.
Sometimes, when turning left (can't make it do it when turning right) there is a clunk and a bang which seems to come from the rear - seems to hit right in the seat of the pants.
It feels like I just drove off a curb suddenly.
Any ideas what this may be.
I have a separate, perplexing problem I will ask about in an different thread.
Thanks a lot for any insight.
Mark and Sher
Mark and Sher
We think its a broken/ damaged anti-swaybar bracket. While both of you are under there check the front axles/CV Boots. You two may want to take the wheel off, check the brake caliper and make sure you get the lugs tightend when reassembling (80 ft/lbs I think). Uhhh that's all we got, Welcome to the board, all of you
Hmmm... this may correspond with the "new" rattling sound of the suspension.
Thank you SO much for your reply.
Thanks for welcoming us.
Clunk & Bang - Still there
We inspected all suspension components and drive train - nothing broken, nothing missing - nothing bent. U-Joints feel tight.
Checked the front axles and CV joints (tugged on them) and they feel reasonably tight - slightly rattley - but no more than for the last 4 years.
They don't bind in a turn or in reverse turns.
We also drained the gear oil from the rear end - as it appears it may be coming from that area - although hard to tell for sure.
There was nothing in the oil - or on the magnetic drain plug, other than wear and tear residue (dark grey powder - very little)
It handles normally.
It only happens under load, turning left - turn left, straighten out, press throttle and clunk bang.. kinda feel it in seat of pants.
It does not happen all the time - 1 out of 5 turns maybe.
Had two people sit in bed of truck and they say it sounds like it's coming from the rear area.
Very odd.
Very odd.
Locker in Rear?
Originally Posted by Robinhood150
Did you get this new or used? It almost sounds like you have a locker in the rear.
How would I tell? - I did buy it used - and I really don't know.
Thanks for the idea... If I do... what does this mean, as far the noise goes?
Mark
jasonty
41
12-23-2018 01:00 PM
ripp96
07-25-2015 02:32 PM
Hamonacracker
07-17-2015 08:33 AM
