Climate Control Diagram? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-04-2003, 08:18 AM   #1 (permalink)
So I've been pulling my hair out trying to figure out why my heat is so weak (99 Tacoma 2.7). The engine operates at normal temperatures. I replaced the T-stat, checked the heater control valve, and had the whole system flushed, including a back flush of the core. None of this made a big difference.
Now I've made a new observation: The heat coming out of the floor vents is much warmer than the stuff coming out of the dashboard vents. I wonder if the air is bypassing the core somehow, with the dashboard vents getting more of the bypassed air.
I'm hoping someone out there has a diagram of the ductwork that they could provide me so I can see if this is possible or likely. I'd really appreciate it...its pretty damn cold in New Hampster.
Thanks,
Tom
NHTacoma is offline
Old 03-04-2003, 10:30 AM   #2 (permalink)
DH6twinotter's Avatar
While I don't have a diagram of your ductwork, I do have a bit of an idea for you. Is your defroster jambed on somehow? Like the setting for defrost and floor boards might be stuck somewhere under the dash. Is there hot air coming out of the defroster vents? I dunno, but thought I'd mention it.
Well, I suppose that really isn't an answer to your question, but thought I'd say something anyways.
have fun.
DH6twinotter
__________________
1990 4Runner: SR5, 2wd, 3.90 rear, 3VZ-E, auto.
15x8 MT classic II rims, 31x10.50 Bridgestone Desert Duellers ($50!), Cobra CB, 3' firestick
Planned stuff: Pre-runner light bar with Hella 500s, small lift
Stuff I'd do if I went crazy: SAS, 7mgte or 1UZ swap, and as much offroad goodies as $$ will allow.
DH6twinotter is offline
Old 03-04-2003, 12:44 PM   #3 (permalink)
Thanks for the idea. The dampers all seem to be behaving normally. Air comes from where its supposed to.
I had thought that maybe my air conditioner was stuck on because that would explain all of the symptoms I'm having, but the compressor doesn't seem to be turning at idle. I need to check it again once the engine has warmed up and with the engine revved because it might be that when I checked it the first time the evaporator was too cold to signal it to turn on, or the clutch might only be engaging at higher rpm. I'm thowing punches in the dark at this point.
Still, anyone with diagrams who could help me out would be great.
Thanks again,
Tom
NHTacoma is offline
Old 03-05-2003, 08:05 PM   #4 (permalink)
Here's a diagram I ran across in my haynes manual. Hope it helps. See attachment.
Have fun.
DH6twinotter
__________________
Old 03-06-2003, 04:54 AM   #5 (permalink)
Thank you very much. I really appreciate the effort. I'll see if I can correlate the diagram to what I find in the car.
Thanks again,
Tom
__________________
'99 Tacoma 4x4 Ext Cab, 2.7 (Kelly)
'93 Porsche 968 Coupe (Ashley)
NHTacoma is offline
Old 03-06-2003, 06:41 AM   #6 (permalink)
Quote:
Not a problem. That's why we are here. To help our fellow Yota owners.
You know, I got thinking that that is a diagram for 89-95 trucks and 4Runners. I'm not sure how close it is to your '99. I would think it is pretty close though, but just thought I'd point that out.
Have fun.
DH6twinotter
BTW, Completely off topic, but I noticed in your sig that you have an 88 Audi 90. Has it been a good car? I got very close to buying a 93 Audi 90 CS. Loved that car. I figured parts would be really $$, so I didn't get it. :cry:
__________________
Old 03-06-2003, 09:01 AM   #7 (permalink)
Alstaz's Avatar
Climate control
Just as a note. it is a common misconception that the AC system will only push cold air. It can be used in conjuction with your defrosters and warm air to clear fogged windows etc. So I don't think that the AC is necessarily the problem. HTH
Al
__________________
Al Florence
TLCA Member
1999 4Runner Highlander - Leather Int, Black Pearl Emblems, SAWs, Downey / Bilsteins, 285/75/16 Bridgestone Dueler Revos, Kenwood Excelon System, Grill Mod, Deckplate, ISR Mod...
1969 FJ40 Land Cruiser 4" 33X12.5 BFG Muds
1971, 1978, 1979 FJ40 Land Cruisers
1997 Collectors Edition Land Cruiser (OME, 285 MTs, Nav system...)
Alstaz is offline
Old 03-06-2003, 10:13 AM   #8 (permalink)
Here's the story on the Audi. It belonged to my sister, who was the 2nd or 3rd owner. She bought a new car and gave the Audi to me when my car crapped out and I needed something for a month or so while I fixed my car. When I took it from her, it had 212K miles and a bunch of minor problems, but ran well. I drove it for a while, then it sat for a while, then I wound up with a girlfriend who needed a car but couldn't afford one, so I let her take it, then she crashed it into a tree, I fixed it up good enough to drive, and she's been using it ever since (though we've broken up...ain't I a nice guy?). A bunch of new problems have ocurred in that time. My basic impression is that the drivetrain will last forever, but that the secondary systems (cooling, electrical, body mechanical) are garbage. You can expect a whole bunch of small problems to drive you crazy, but the cars will keep on trucking forever. One of my best friend has a '90 quattro coupe, and he's had a bunch of small problems too...but its never stranded him.
As to the AC, on my truck the defrost setting on the air damper control signals the AC to turn on to fascilitate defrosting. My thought is that either that switch, or the main AC switch, is stuck on. That would explain why the heater isn't blowing as hot as it should be and also why my mileage is bad. I've looked at the compressor while the car idled and it wasn't turning, but the car was cold and it was cold outside, so the thermostat in the evaporator might have been too cold to signal it to turn on. Its a long shot, but its worth another look.
Thanks again, guys.
Tom
__________________
NHTacoma is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Climate Control Went Haywire khvn 95.5-2004 Tacomas & 96-2002 4Runners 4 02-05-2007 05:47 AM
Climate Control lights ? CANADA4RNR 86-95 Trucks & 4Runners 7 02-19-2006 03:42 PM
Climate Control Lightbulb Steveh29 95.5-2004 Tacomas & 96-2002 4Runners 3 01-31-2005 07:35 PM
limited climate control trainerdude 95.5-2004 Tacomas & 96-2002 4Runners 4 12-04-2004 11:30 AM
Climate Control Backlight smittie6 95.5-2004 Tacomas & 96-2002 4Runners 2 10-15-2003 10:47 AM
2009 InternetBrands, Inc.
