Clearance
Clearance
im thinking about adding a 3 inch body lift to my Runner and does anyone know if i could fit 33's under it . Oh ya its a 94 v6 just incase it changes in the years
i think they will fit,but it also depends on what size rims your planing on using.i have a 3in body lift on my 94 pickup and i'm running 32's on 15x8 with about 5in backspacing and no problems, but i was bored one night threw the rims and tires on my 4Runner on my truck and there 33's on 15x10's with 3.25 backspacing.Drove it to work the next morning and got major rubbing at about half steer.i know i should have checked them out better when i put them on but by the time i got done it was dark looked alright sitting on the nice level driveway :pat:
Re: Clearance
If you do a 3" body lift I believe you will have to do some other stuff as well, IE brackets relocated or lines extended or whatever. I think the transmission lever might need to be adjusted or something as well.
kawazx636
10-06-2021 03:03 PM
scott90
10-04-2015 09:21 AM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
