| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
cleaning top of cylinder block b4 head install
__________________
'94 std cab 22re 4x4 stock |
#2 (permalink) |
Go to checkers, autozone, etc. They have an engine flush that you put into your oil thats supposed to clean everything out. I used it and it seemed to work.
#3 (permalink) |
Is the block in your rig? if so and you took off the top end only you could pressurize the oil system to push out the debri from the oil rails. I'd recommend trying to get as much out as possible, since those feed directly to your head and if you plug one of your camshaft oil holes you could do some damage.
#4 (permalink) |
at most the debris is dust from the head i dont think any chunks large enough to clog any ports got anywhere.
so where do i go to learn about pressurizing and where i can get it done at? or should i put everything back together and drive it immediatly down to the nearest auto mechanic hoping and praying that no damage is done?
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| OME Lift...last questions B4 install. | k_southman | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 02-25-2007 10:46 PM |
| Honing Cylinder w/o pulling the block | Bill | General Vehicle Related Topics (Non Year Related) | 5 | 02-03-2007 01:20 AM |
| cylinder block cleaning | benwahballs | 86-95 Trucks & 4Runners | 1 | 10-12-2006 03:50 PM |
| Block Deck Cleaning before new headgaskets | FireMan | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 03-31-2004 03:48 PM |
| cleaning cylinder head and valve cover | Tom | Maintenance & Repair Archives | 1 | 12-08-2003 11:35 PM |
