Cig. Lighter Quit
Cig. Lighter Quit
I was topping of my spare with my compressor and it died, fuse was blown so I replaced it with another 15Amp blade fuse, it worked for about 5 seconds, then nothing again, only the fuse is intact.
Any Ideas?
Thanks,
Lamm
Any Ideas?
Thanks,
Lamm
when mine did that it was the fusible link wire in the 12v adapter itself.
If so, you'll likely need to pull the center dash (pretty easy), and check the connection there... solder in some new link wire, or just some any-ole-wire (not my recommendation) and you should be good.
I have a reference somewhere... hmmm....
https://www.yotatech.com/forums/show...ible+link+wire
mine went out....no fuse blown, had to put the key to off acc on over and over a few times. it started working than went out again. the tool i was using was drwing to much current....it works now tho
kawazx636
10-06-2021 03:03 PM
ToyotaMD
09-22-2015 04:49 AM
