Cig Lighter Mod info needed (this should be an easy one)
How can I make my cig. lighter offer power full time. In other words, I'd like to charge my phone, and not have to keep the ignition in the "on" position.
Here is the write-up listed in the Tech section on here, this guy knows what hes doing too...I've used his write-ups before.
http://www.top4runners.com/ja/electr...ml#poweroutlet
Happy modding!
Fink
Happy modding!
Fink
thanks for the responses, the Bajataco write up on this site and the one 4x4 fink suggested look totally different. I'm sure there is more than one way to do this, is it really necessary to insert an in line fuse? I'll be powering the usual suspects...phone charger, air mattress pump, ipod, etc.
Any more input is appreciated
thanks
thanks
you should definitely use a fuse...and, if you run a wire from the battery (which is the way to go, imho), you should put the fuse as close to the battery as possible.
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
