YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 07-08-2010, 06:58 AM   #1 (permalink)
Personal Sales Rating: (0)
Chipped Harmonic Balancer
Just discovered that my harmonic balancer is chipped, inner lip. About 1/2" of the lip is missing, belt doesn't appear to be damaged. Is this something that I need to replace or is it ok the way it is?
bob
__________________
1997 Toyota 4Runner Limited 3.4L
Mods: Deckplate, ISR, Various LEDS
Exhaust: Magnaflow Cat and Muffler
Bobs4Runner is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 07-08-2010, 07:02 AM   #2 (permalink)
scuba's Avatar
Replace the thing before the rest of it flys apart. I've seen pictures of a flywheel that came apart and went through the bellhousing and through the trans tunnel into the vehicle.. Scary
__________________
SHUT UP AND WHEEL.
My 99 Tacoma Single Cab build.
Now representing All-Pro Off-Road. Call us for all your suspension and armor needs. 951-658-7077
scuba is offline
Old 07-08-2010, 07:18 AM   #3 (permalink)
Threadstarter [OP]
Ok...I may be talking about the wrong pully. This one is at the bottom of the engine (3.4L). Its the Bottom pulley with (3) belt going to it. The chip doesn't appear to be new, doesn't look shiny, its rusted over.
__________________
Old 07-08-2010, 08:20 AM   #4 (permalink)
j-man's Avatar
thats not your flywheel - its just the crank pully - if its rusted and the belt isnt touching it - dont worry about it.
__________________
01 tacoma-sold, 98,99,2000 4runners sold
06 tundra 4x4 v8....soon to be built up...
2003 Landcruiser 285 BFG At's and outback roofrack
My Baja Trailer Build: http://forum.ih8mud.com/showthread.php?t=179520
www.samsonfab.com
j-man is offline
Old 07-08-2010, 08:34 AM   #5 (permalink)
scuba's Avatar
Actually. A chipped pulley can be bad as well. It can cause the balance of the crank to be thrown off (maybe what the harmonic balancer is for? not sure) and mess up bearings and junk inside.
Go get one from a boneyard and replace it.
EDIT: And a flywheel goes between the clutch disc/ pressure plate & the engine.
__________________
SHUT UP AND WHEEL.
scuba is offline
Old 07-08-2010, 08:46 AM   #6 (permalink)
OEM Nazi
Personal Sales Rating: (17)
Staff
DeathCougar's Avatar
Send a message via AIM to DeathCougar Send a message via Yahoo to DeathCougar
Title fixed.
Get that balancer replaced before it does more damage.
__________________
Tacoma miniheader install kit Now available! Click here for ordering information
Quote:
Originally Posted by BigBluePile View Post
Hmmm, dunno. Ask the oem Nazi DC.
Quote:
Originally Posted by kiyobrown View Post
I'll cut you.
DeathCougar is offline
Old 07-08-2010, 10:14 AM   #7 (permalink)
Threadstarter [OP]
Yea, may have to go to a junkyard to search for one. Its $330 for a new one. How hard it is to take apart and re-install?
__________________
Old 07-08-2010, 11:47 AM   #8 (permalink)
profuse007's Avatar
The best way to take off crank pulley is to use impact wrench. installation required a crank holder tool (not so special tool can be bought for ~40bucks) and torque wrench.
look at some timing belt DIY, anybody can do it.
__________________
o0 4Runner, Sequoia Wheels on 265/70/16, Airlift, Denso 4300K, 199mm Brakes
Techstream V5.0 w/ Openport 2.0
profuse007 is offline
Old 07-08-2010, 12:04 PM   #9 (permalink)
scuba's Avatar
Quote:
Your answer lies in the post below.
Quote:
There are PLENTY of write ups on how to change the timing belt on the 3.4, and pulling off that pulley is entitled in that job.
Here's the FSM. Most mechanical engine stuff is the same from Taco-4Runner.
http://www.ncttora.com/FSM/2003/index.html
__________________
SHUT UP AND WHEEL.
scuba is offline
Old 07-08-2010, 01:54 PM   #10 (permalink)
brian2sun's Avatar
If the pulley is chipped bad enough to throw it out of balance, then what will probably happen is over time the keyway will get rounded out, the timing will get messed up and the truck will start to run bad, then it will ruin the bearings and ultimately the crankshaft itself (which = new lower engine).
The crankshaft pulley is torqued to 217 ft lbs, so it's not exactly easy to R&R. To break it loose without special tools, one trick on the 22r (thanks to 4x4wire.com) is to put a socket on it with a breaker bar and wedge the handle against the Driver's side frame rail making sure it's out of the way of the radiator. Then disconnect the coil wire from the distributor and ground it so the engine won't fire up (which would be very bad if that happened). Then just bump the engine and it will break the bolt loose. I actually just did this last friday while replacing the timing cover on my buddy's '88 22RE and this method worked like a charm. I don't see why it wouldn't work on the 3.4, but I haven't tried it personally. Instead of grounding the coil wire though, you would disconnect the ignitor located on the pass. side fender for ther 3.4.
Getting it back on tight may be harder. On the 22RE, we were able to torque it back down once all the belts were back on and tight with just the resistance of the engine/belts. But, I'm not sure if there would be enough engine resistance to torque the 3.4's back to 217 ft lbs. - which is very important. There are a few threads out there where people didn't properly torque it back down and it ate up the keyway again. I don't know how much help this will be for you since I'm not sure how this trick works on a 3.4, but it's food for thought if nothing else.
__________________
'97 4Runner SR5 3.4L 4x4 - Lifted on 35s, Geared, Dual Locked, and Armored
'98 Tacoma Regular Cab 2.7L 5-speed 4x4 - Bone Stock DD
brian2sun is offline
Old 07-08-2010, 03:09 PM   #11 (permalink)
I accidentally chipped my brand new crankshaft pulley while installing it. That pulley is about 10lbs and the chip was a couple of grams in weight. I installed it and have been driving fine for 30,000 miles. The choice is yours.
__________________
1997 4runner Limited 4x4- Family owned since 12/96
rjaudi is offline
Old 07-08-2010, 05:05 PM   #12 (permalink)
tunnelmotor99's Avatar
If it only has a small chip, I would just let it roll. That little bit of missing metal shouldn't make any noticeable difference in the balance. Oh, and the comment about using the starter to break the bolt loose....YIKES
__________________
'97 4Runner SR5 2WD AT, Toyota brush guard FOR SALE!!), Toyota "Mr. T" Gold Emblem Package, K&N Air Filter, Trans cooler bypassed, 5000K HIDs, '99 Headlights, clear corner & turn lenses.
tunnelmotor99 is offline
Old 07-08-2010, 05:47 PM   #13 (permalink)
brian2sun's Avatar
It's a common technique to break the bolt loose, just don't do it if you're not comfortable with your skills. Like I said I did it last friday and it worked perfectly and was much easier than renting tools or taking it to a shop and paying out the nose:
http://www.4x4wire.com/toyota/maintenance/timingchain/
__________________
Old 07-09-2010, 10:58 AM   #14 (permalink)
Threadstarter [OP]
I'll take a pic of it this weekend and post it. Its a small chip that looks like its been there awhile. The orignal put the new motor in it, so it could of happened then. I haven't messed with anything near there...knock on wood.
On a good side note, New front cross drilled rotors and pads came in...AND my ToyTec 3"OME Lift!!!!!!!!!!
__________________
Old 07-09-2010, 01:11 PM   #15 (permalink)
gpcollen1's Avatar
Bumping the engine is no big deal to break the bolt loose. I don't really see the need to do that though as making the tool to hold the pulley while you break the bolt costs less than 10 bucks using a 2x4 and some hardware. I would post the pic I have of mine but photobucket is acting up right now. I did repost the pic in a timing belt thread a few months back if you want to take a look.
__________________
'99 SR5 Sport - Desert Dune: AirRaid MIT, OEM Air Filter, Toyo 265/75/16 ATs, Deckplate, PP Springs and Bilsteins, Cheapo nerf bars, Injector replacement impending
gpcollen1 is offline
Old 07-10-2010, 09:35 AM   #16 (permalink)
eddieleephd's Avatar
if you pull that pulley off you would see a metal balance weight where they balanced that part to avoid uneven wear however the choice is of course yours. I will not give to or take away from the possible damage that can be caused by this and will be increasing the whole time the engine is running.
__________________
'99 3.4L 4x4 All Manual Taco
2.5" lift OME CO and Alcan Leafs
Deck Plate Mod.
eddieleephd is offline
Old 07-19-2010, 10:46 AM   #17 (permalink)
Threadstarter [OP]
Updated with pic
Finally was able to get pics on my semi free weekend. I don't think it looks that bad.
Chipped Harmonic Balancer-1997-4runner_1.jpg   Chipped Harmonic Balancer-1997-4runner.jpg
__________________
Old 06-02-2012, 08:00 AM   #18 (permalink)
did you end up using this pulley or replacing it?
I have a similar scenario except on the outside edge. I have checked and the belt doesn't seem to touch the edge.
Replace or reuse?
Click the image to open in full size.
camdenbuck is online now
Old 06-02-2012, 10:12 AM   #19 (permalink)
rworegon's Avatar
If it was mine, I'd replace it just to be safe. About $305+shipping from online OEM dealers.
Napa Online, $268 Balkamp brand.
RockAuto has a Dorman brand for $180 or so...can't speak to quality.
rworegon is offline
Old 06-02-2012, 12:53 PM   #20 (permalink)
If I had the moolah...I'd be prone to listen
I'd buy the part. Went to the dealer today and the lead tech said to make sure the belt clears. Nowhere near touches this spot. He said the chip is negligible and since material is still there, it won't have an effect. He told me to make sure it was smooth. Bought a $60 torque wrench for that 217 ft-lb crank bolt tightening ceremony...(new bolt)
Now I have to get that grey goo that goes between the fan bracket and lower timing cover on water pump side.
Fiance says hurry up. I say slow and steady wins. Don't want to go in twice!
Thanks for all of your support!
Yotatech
4WD Truck
Paid Advertisement
Tags
30, 34, balancer, chip, chipped, diy, harmonic, hold, honda, messed, small, timing, tool, toyota, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
