Chevy rear swap question - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-23-2004, 11:17 AM   #1 (permalink)
Send a message via AIM to roktoy84
I know a lot of you people out there are running the 88-98 Chevy rears. And a lot of you use a dual shackle setup. My questoins are:
1: is the dual shackle setup unpredictable in an off camber situation?
2: is there anybody out there running a Buggy spring setup instead?
3: How do the Chevies flex without the dual shackle setup?
4: How would I get around a 5 inch lift using the chevies without running blocks?
Any feedback on this would be appreciated
roktoy84 is offline
Old 02-23-2004, 11:26 AM   #2 (permalink)
sschaefer3's Avatar
1. I don't think so if done correctly
2. I don't know
3. I don't know we run a dual setup
4. Keep deaming, your looking at 4" of lift in a pickup and 3" in a 4Runner. The entire point of useing the springs is that they are soft, if you add leafs or make them stiffer you have defeated the purpose.
The other thing that I think very few realize is that the Chevy bushings are just like the Toyota bushings in the 3rd Gen lower control arms. The rubber is meant to flex and the inner sleeve has grip spikes, you following this? The rubber moves not the bolt pivot. If you use the Chevy shakle, which has the same grip spikes on the rear of the springs and you make a custom shakle for the Toyota frame to Chevy spring that is your best bet. The spiked bushings act as springs to pull the dual shakle back in the correct direction and it will never invert. You'll also need to shim the springs becase the front mount will then be on the flat part of the frame and the front of the diff will then in turn point downward. You'll also need to lower the bump stop points because if you push the Chevys beyond perfectly flat you'll sag em.
It works really well if you do it right, from what I have seen on Pirate, most miss the boat.
Here is ours:
http://fastq.com/~sschaefer/store.html#63Chevy
__________________
Steve Schaefer
WWW.SonoranSteel.Com
Suspension Lift Kits * Rock Sliders * Straight Axle Conversions * 4Runner/FJC Rubicon Express Lower Links * Accessories * Daystar Products Dealer * TJM Bull Bar Dealer * Deaver Leaf Spring Dealer * Tokico & Bilstein Shock Dealer * ViAir Dealer * Total Chaos Dealer * TOYTEC Dealer * and like everyone else a Trail Gear Dealer
sschaefer3 is offline
Old 02-23-2004, 11:36 AM   #3 (permalink)
I understand bout the shackles. as for the pinion pointing downwards, how many degrees is the shim you're using.
roktoy84 is offline
Old 02-23-2004, 11:37 AM   #4 (permalink)
sschaefer3's Avatar
Ours worked out to 6 degrees.
__________________
Steve Schaefer
Old 02-23-2004, 03:57 PM   #5 (permalink)
Quote:
Uh, no. I am running 5" All Pro fronts, and the chevys in the rear with a rancho add-a-leaf. This results in a spring that flexes almost exactly the same as the AP fronts, and gives about same lift as the AP fronts (which I admit sag like hell). Flexes very well.
__________________
86 4 rnr, original owner, SAS, LCE EFI Pro, lotsa doghair
alabamatoy is offline
Old 02-23-2004, 04:27 PM   #6 (permalink)
why do you want chevy rears??? is there a advantage??? are the to wide???
lunatic14r is offline
Old 02-23-2004, 04:30 PM   #7 (permalink)
Cebby's Avatar
Send a message via AIM to Cebby
Quote:
You do know they are talking about springs, right?
__________________
UZswap.com
A site dedicated to sharing info for swapping the Toyota/
Lexus UZ (V8) engines into Toyota Trucks and 4Runners.
My 4Runner
1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys,
low lift, hacked fenders, tubbed firewall, custom armor
TOOLandFAB.com
A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion
Cebby is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
chevy spring swap question 94banshee The Fab Shop 7 11-20-2009 03:50 PM
Chevy spring swap question drguitarum2005 95.5-2004 Tacomas & 96-2002 4Runners 4 05-30-2006 09:10 AM
89 Chevy spring swap Question & Request. dwh91102 86-95 Trucks & 4Runners 4 01-15-2006 06:24 AM
5.0 Chevy Swap blainelukens The Fab Shop 2 05-16-2005 05:16 PM
chevy 4.3 swap.. playboy 95.5-2004 Tacomas & 96-2002 4Runners 4 01-05-2004 08:01 PM
2009 InternetBrands, Inc.
