chevy 4.3 swap.. - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-04-2004, 07:57 PM   #1 (permalink)
chevy 4.3 swap..
Im going to do a engine swap this spring. This is my first swap. I was wondering if anyone else has done it before and has any of the specs on it. Ive heard the tranny doesnt need to be changed so thats good. How about the alternator, power steering, fuel system and everything else. I know I need new motor mounts. Any info on this would be great.
__________________
84' pick-up. 6" lift with 33" BFG
22R
looking for a frame!
playboy is offline
Old 01-05-2004, 01:35 AM   #2 (permalink)
toy283's Avatar
Send a message via ICQ to toy283
Alternator: Use your Toyota with an aftermarket bracket or wire a GM into your electrical system. Either option is relatively simple, the GM alternators off higher outputs for less money though.
Power steering: Same thing, either mount your current pump with an aftermarket bracket or plumb in the GM one.
EFI: A little trickier. Some GM TBI systems require on 15psi, some MPFI systems require 50-60psi. If it is comparable with Toyota pumps (I have no idea what Toyota pressure is), then you can use the stock pump. Otherwise, you need to swap it out with one of the appropriate output pressure.
__________________
Dave
Currently own no Toyotas :(
toy283 is offline
Old 01-05-2004, 09:22 AM   #3 (permalink)
i have a carb. Will that be compatible?
__________________
22R
playboy is offline
Old 01-05-2004, 10:25 AM   #4 (permalink)
amusement's Avatar
Exclamation
If your serously considering to swap in a chev 4.3 then you will need to read "Toyota Truck & Land Cruiser Ownsher's Bible" by Moses Ludel. He spends some damn good quality time explaining the swap.
amusement is offline
Old 01-05-2004, 08:01 PM   #5 (permalink)
toy283's Avatar
Quote:
If you're putting EFI, you'll need a new fuel pump. If you're putting on a carb, you'll still need a new fuel pump as your current one is engine mounted and will go away with the engine. A carbed V6 would be a lot easier to install, but there weren't many carbed 4.3's.
__________________
Dave
toy283 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
chevy 4.3L swap runnerboy97 The Fab Shop 18 06-03-2007 06:55 AM
chevy leaf swap? hirsche23 86-95 Trucks & 4Runners 3 04-30-2006 11:53 PM
5.0 Chevy Swap blainelukens The Fab Shop 2 05-16-2005 05:16 PM
Chevy rear swap question roktoy84 95.5-2004 Tacomas & 96-2002 4Runners 6 02-23-2004 04:30 PM
Chevy Swap! descendents Offroad Tech 12 06-20-2003 04:32 PM
2009 InternetBrands, Inc.
