Check engine light help
My 4runner has been getting terrible gas mileage, jumping at stop lights, idling high and loss of power. I went to Autozone to get the codes and it came up with this. I have a 1997 4runner V6 SR5 2wd with 162,000 miles.
P300
P302
P304
P305
P306
P300
P302
P304
P305
P306
P300: random/multiple cylinder misfire detected-- Misfiring of random cylinders is detected during any particular 200 or 1000 revolutions
P301-306: Misfire in corresponding cylinder. In your case cylinders 2, 4, 5, and 6.
I got double, the sticker on the front of the motor--told me too. there was single prong autolites that were wore out that i changed. not sure how much double vs. single matters though.
I had similar problem and changed all spark plugs and wires.
After two weeks problem returned with misfire codes: 300, 303, 305 (dealer said there was 50% cylinder 5 misfire).
They changed all (3) ignition coils and so far no problems with misfires or check engine light...
Read this over, but the high idle points to a vac leak somewhere (unmetered air is getting in after the MAF) Of course you could have more than one problem.
https://www.yotatech.com/forums/f2/c...ighway-128206/
06-01-2021 01:51 PM
