Check Engine light @ 75k miles - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-26-2004, 05:46 PM   #1 (permalink)
Poke Runner's Avatar
Does the check engine light automatically come on @ 75k miles? Does it do this to get you to take it to the dealership to get the 75k maintenance?
I found the list of codes to run the self diagnostic, that's my next step.
Everything seems to be running smoothly.
thanks
__________________
2000 SR5 4x4 Sport 5spd
Amsoil Air Filter
Michelin XCX/APT 265/75/R16
Poke Runner is offline
Old 09-26-2004, 05:50 PM   #2 (permalink)
No, it is telling you something is wrong. The check engine light means you should get the engine control system checked and repaired.
Gadget
Gadget is offline
Old 09-26-2004, 05:54 PM   #3 (permalink)
Rick F.'s Avatar
Location: Far western Kentucky (transplanted from central PA)
Send a message via AIM to Rick F. Send a message via Yahoo to Rick F.
I see that you have an Amsoil air filter. $10 says that your MAF needs cleaning. It's pretty simple. You'll find writeups in the Tech section for the 3rd gens.
__________________
'00 SR5, Desert Dune: 4" Deckplate, Amsoil TS-115, Bilsteins, Brembo rotors w/Performance Friction pads, Fiam Highway Blasters, Sylvania Silverstars, Hella Micro DE Fog Lights w/Hella Yellow Star Lamps - SOLD 1/24/09
'08 Sport, Salsa Red: Hella Optilux fogs, Silverstar Ultra Hi beams. Pending: Borla dual catback, CAI, shocks
Rick F. is offline
Old 09-26-2004, 05:54 PM   #4 (permalink)
betcha its your front 02 sensor
bob
Bob_98SR5 is offline
Old 09-26-2004, 06:28 PM   #5 (permalink)
"I see that you have an Amsoil air filter. $10 says that your MAF needs cleaning. It's pretty simple. You'll find writeups in the Tech section for the 3rd gens."
That makes sense. I think I've had the AMSOIL filter in for a while and its due for a cleaning.
thanks
__________________
Amsoil Air Filter
Old 09-26-2004, 08:27 PM   #6 (permalink)
halza's Avatar
o2 sensors need to be replaced most likely, don't go to the dealer they'll rape you, I just did mine a few months ago when my toy hit the 100k, it was the 02 sensor.
__________________
1997 ltd, 275/70/16 on 16x8 PRO COMP wheels, elbow off mod, amsoil filter, hella fog lights.[font=Arial Black]
halza is offline
Old 09-26-2004, 08:46 PM   #7 (permalink)
kevin444's Avatar
Send a message via AIM to kevin444
Quote:
When i bought my 2000 4runner sr5 it haf 104k miles. The seller told me the check engine light and got that fixed. I told him what was wrong and he said something o sensor. SO well thats good enough to me that he's saying oxygen sensor!.
__________________
02 4runner conversion complete!
kevin444 is offline
Old 09-26-2004, 08:53 PM   #8 (permalink)
SloPoke's Avatar
Send a message via AIM to SloPoke Send a message via MSN to SloPoke Send a message via Yahoo to SloPoke
It could be something as simple as your gas cap gasket, an o2 sensor, your cat. conveter pluggin' up, the the big vac. line into the air box isn't connected or is pinched, ect. ect. ect.
Gadget is right. You should get it checked.
__________________
Yoats & stuff
SloPoke is offline
Old 09-26-2004, 09:03 PM   #9 (permalink)
SpecializedBrder's Avatar
Send a message via AIM to SpecializedBrder Send a message via Yahoo to SpecializedBrder
Is there such a thing as catalytic converter cleaner? because mine is definietly clogged or not working right and my engine is throwing a code for it and getting it cut off is gonna be a pain.
__________________
185K Miles and Rising
My 4runner 1996 Toyota 4runner Base 2.7 4cyl 4x4 Desert Dune w/Deckplate Mod, BFG KOs,Alpine CDA-7894, Rockford Fosgate Power 500a2 powering an Alpine Type R 15' sub, Rockford Fosgate 200a2 powering 5 1/4 Alpine type R rears, Kenwood KAC-7201 150w x 2 powering front polks,Cosmo Fuel Pressure Regulator, Magnaflow Exhaust,99+ headlights,Hoodscoop, Soon to be turbo(have the manifold, someone sell me a turbo damn it!)
SpecializedBrder is offline
Old 09-26-2004, 09:31 PM   #10 (permalink)
SloPoke's Avatar
You sure your code is the cat and not the o2 sensor?
Your cat is flanged so it's just a simple unbolt and bolt replacment. Why's that goina be a pain?
__________________
Yoats & stuff
SloPoke is offline
Old 09-26-2004, 09:49 PM   #11 (permalink)
X-AWDriver's Avatar
Quote:
Convertors don't get clogged with "stuff" so to speak,when they are "clogged" it usually means the ceramic material has broken apart or in cases of running high exhaust gas temps then the material can actually be melted. Replacements are usually under $100.
__________________
'99 4Runner Highlander 4wd
E-locker,rear diff and deckplate mod * 265/75/16 Nitto TerraGrapplers * Yakima Load Warrior rack * clear corners/signals * Tacoma skidplate * Silverstar lamps/fogs
Alpine CDA-9831,Bazooka EL Series 250w amp,MTX 10" sub
X-AWDriver is offline
Old 09-26-2004, 10:03 PM   #12 (permalink)
My 3rd gen 2.7 has the catalytic converter welded to the downpipe
__________________
Old 09-26-2004, 10:48 PM   #13 (permalink)
kevin444's Avatar
please buy my LC headers and High Flow Cat
That will take kare the problem. Ill throw in a e10 torx socket!
__________________
kevin444 is offline
Old 09-27-2004, 05:51 AM   #14 (permalink)
MTL_4runner's Avatar
Send a message via AIM to MTL_4runner
Quote:
bob
I'd bet money you're right.
Only way to know for sure is to pull the actual code number and post it when you get it.
__________________
- Jamie
1996 4Runner SR5 4X4 Auto
Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift
Best OBD II scan tool I have used!.
.....and I am AMERICAN!
MTL_4runner is offline
Old 09-27-2004, 03:31 PM   #15 (permalink)
SloPoke's Avatar
How much you need to get for your LCE header and hi flow cat?
Would you seperate? I NEED a hi flow cat but would only LIKE a header.
__________________
Yoats & stuff
SloPoke is offline
Old 09-27-2004, 03:33 PM   #16 (permalink)
SloPoke's Avatar
It came stock welded up?
__________________
Yoats & stuff
SloPoke is offline
Old 09-27-2004, 09:53 PM   #17 (permalink)
After work I stopped by Autozone to get the diagnostic run. They do it for free. I was a little pressed for time, it only took 5 minutes.
The code that came up was P0120 which is the Throttle Position Sensor/Switch. A circuit malfunction from what the guy told me.
What does this mean?
Is this something that can create a domino affect to other parts?
They have the part for $79.99. Where does this thing go anyways? Besides my ace if it will include lots of labor.
But the weird thing was that the check engine light turned off when I left the parking lot. Did it do that because the diagnostic was run?
Thoughts?
__________________
Amsoil Air Filter
Old 09-28-2004, 05:32 AM   #18 (permalink)
Thoughts?
That is a pretty rare code for the 4runner but yes, that does indicate a bad TPS (I would get it from the dealer instead tho).
See the link to all the codes here:
http://www.yotatech.com/showthread.p...ighlight=P0120
No, you shouldn't see any domino effect except maybe bad gas mileage.
It goes right on the top of the engine, very easy to get to and replace.
You can see it (black part) attached to the left of the throttle body in this pic:
Usually when they finish pulling the code they also clear it so if the part is still bad you will see the CEL come back on to signal that the problem has not been fixed and if you pulled it again you would see the same code again.
__________________
- Jamie
Old 09-04-2005, 10:16 PM   #19 (permalink)
Did you end up purchasing this part from the dealership? I was curious what one of these cost...
__________________
'99 4Runner, SR5 V6 5 speed
'99 Jetta TDI, 5 speed
RuffRider is offline
Tags
1996, 2000, 2003, 4runner, cat, cel, check, codes, diagnostic, engine, forerunner, highlander, jetta, light, p0120, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Engine swap/check engine light? spacoli 86-95 Trucks & 4Runners 1 11-29-2006 07:39 PM
check engine light 4runnerx3 86-95 Trucks & 4Runners 2 09-06-2006 08:26 PM
Engine Miss/Check engine light - Possibly TPS? Extremesolo 95.5-2004 Tacomas & 96-2002 4Runners 2 09-17-2005 09:58 PM
check engine light ajz399 95.5-2004 Tacomas & 96-2002 4Runners 3 03-22-2005 08:12 AM
check engine light + engine miss descendents 95.5-2004 Tacomas & 96-2002 4Runners 6 11-03-2003 07:51 PM
2009 InternetBrands, Inc.
