check engine light...
my check engine light came on last night, but when i got on the highway, after about 10 miles it went away. i just recently did the timing belt, and spark plugs and then the seafoam cleaning. will the error code be still stored if i go to autozone to get it checked out?
yes, check out that thread. that's once reason I've only done the 1/3 can in the PCV and full can in the gas tank. it seems the people who've actually put it in the crankcase have experienced this.
likely will have to be replaced
I for one would only use a Toyota replacement, had bad luck with aftermarket ones
actually does anyone know of a direct plug in aftermarket replacement
I did my front one two months back due to a PO135 code.......now the next one back...after the cat popped a PO136
would be great to save a few bucks, and get a direct plug in one that is as good as the one I would get from the dealer
thanks
thanks
