Sign in using an external account
| 95.5-2004 Tacomas & 96-2002 4Runners 4th gen pickups and 3rd gen 4Runners |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
check engine light
#2 (permalink) | ||
Personal
Sales Rating: (0)
There are tons of reasons the light may have come on and gone off. If it doesn't come back on I wouldn't worry about it but if your really concerned about it any dealer can plug it in and get the code to tell you why it came on. As far as your radiator to burp it here's a quote from Jay
Quote:
__________________
2006 Tundra Double Cab TRD Offroad 4.7 IForce Bilstein 5100's, 285 BFG's, Panther Wheels, Limo Tint 1994 4-Runner SR5 5 Speed SASed, Detroits, Armored, Dual Cases, 37" MTR's Build up /f199/ukmyers-1994-4runner-build-up-thread-104000/ Need Toyota Parts? www.davezoffroadperformance.com Quote:
#3 (permalink) |
Personal
Sales Rating: (0)
The insturctions quoted above pretain to a complete refill of a cooling system.
If your low on antifreeze, warm up the vehicle with the cap off. Only keep the coolant about a 1/4 below the neck of the radiator ( the level will raise while the coolant warms up, be prepared for overspill). You should eventually see it start to flow. At this point top off the radiator, and install the cap. The gurgling noise should go away. Common causes for low coolant level: Water Pump Housing or wear Radiator Upper tank crack Headgaskets Upper Radiator hose manifold As for the check engine light, I cant immediatly think of a good reason how it could be related to low coolant level. You would need to retrieve the diagnostic trouble code. Then I would have a better idea where to point you. Jay
__________________
Jay 98 X-Cab Tacoma 3.4L Manual Trans. | TRD Fender Flares | Weld Wheels w/ 31 x 10.5's Jason Larsen Master Diagnostic Technician - Beaverton Toyota (Portland, Oregon) Wendsday - Saturday by appointment only. (503)626-7200 (ask for me by name) Last edited by Jay; 12-19-2002 at 11:41 PM. |
#4 (permalink) | |
Personal
Sales Rating: (0)
Sorry for the misquote Jay.
__________________
2006 Tundra Double Cab TRD Offroad 4.7 IForce Bilstein 5100's, 285 BFG's, Panther Wheels, Limo Tint 1994 4-Runner SR5 5 Speed SASed, Detroits, Armored, Dual Cases, 37" MTR's Build up http://www.yotatech.com/showthread.php?t=104000 Need Toyota Parts? www.davezoffroadperformance.com Quote:
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Engine swap/check engine light? | spacoli | 86-95 Trucks & 4Runners | 1 | 11-29-2006 06:39 PM |
| check engine light | 99SR5 | 95.5-2004 Tacomas & 96-2002 4Runners | 23 | 05-05-2006 11:10 AM |
| Engine Miss/Check engine light - Possibly TPS? | Extremesolo | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 09-17-2005 08:58 PM |
| Check Engine Light Again :( | kryptik | Maintenance & Repair Archives | 8 | 04-14-2005 06:12 PM |
| check engine light + engine miss | descendents | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 11-03-2003 06:51 PM |
