YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 05-31-2009, 12:32 PM   #1 (permalink)
Personal Sales Rating: (0)
Check Engine 4cyl. 2.7L
I guess I will say that just a day ago I drove 200+ miles with no check engine light and enough chevron techron fuel addative for up to 32 gallons with a full tank of gas (18.5gal).
4 months ago my engine felt real rough like it was missing w/ no check engine light I only thought to throw a fuel addative to it. I ended up using the lucas oil little bottle and no noticeable improvement and not knowing that the Chevron techron was the way to go I waited till a light would come on.
3 weeks ago a Check Engine light came on with a misfire code in the 3rd cyl. After swapping the coil pack and rechecking code it came up still the 3rd cyl. PRIMARY AND SECONDARY. At 116,000 miles I wasn't happy to have issues with the motor. I did a compression test that showed that the bad cyl. was @ 130lbs and the others were @155 & (2)@ 150lbs. Without getting to do a leak down test and an injector service thanks to a friend who's a Rover mech I don't know where the issue was.
After running this tank of techron I will be curious to find out that I am getting more compression in the 3rd cyl. I put good gas in I thought shell/76 were good? I'm no mechanic but think simply but is this a red flag for something that might be in the future? To do an injector cleaner where is the valve to hook up the injector cleaner system?
dayrunner is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 06-01-2009, 03:43 PM   #2 (permalink)
KrashDH's Avatar
I had a very similar issue to you a bit after I bought my 99 tacoma 4x 2.7, w/ 120k. It had no power (not like the 2.7 has a lot). Changed out most everything possible for a misfire first (plugs, wires, etc) and that was no help whatsoever.
I then had it taken to a shop to have the compression checked. If I recall I had low compression in my 3rd as well. I believe it was less than what you listed for yours. I consulted a buddy and he suggested that I had a bad valve.
So we took a gamble and tore everything down, and behold I had a burnt exhaust valve. It was pretty bad, it wasn't circular anymore, hence there was a void, which in turn created the bad compression. It seemed that that particular valve was out of adjustment (maybe over tightened) from the factory.
While I had everything apart I had the head re-surfaced and I replaced ALL if the valves (intake and exhaust) for good measure even though the others looked ok. (local machine shop, very good rep) As well, because I was in there, I did all of the timing stuff as well (chain, guides, belt, etc.) and new gaskets.
I now have 161k and she runs like a charm. No issues whatsoever. It was scary for me as this was my first real project on the truck. thankfully I had my buddy who helped a ton.
To answer your question, I would say treat it as something that if not taken care of could get worse in the future. Hopefully though it may be something simple.
KrashDH is offline
Old 06-01-2009, 06:56 PM   #3 (permalink)
Threadstarter [OP]
I wonder if the valve is gummed up and just needs a good dose of techron fuel addative for 4 or 5 tanks? I also had it smogged about 2 months ago and it passed like it was brand new. With the compression being just a little lower than the others as well as only haveing 116k miles it seems like a valve is gummed up. I heard that ethanol is no good for your valves??????
Old 06-01-2009, 07:15 PM   #4 (permalink)
KrashDH's Avatar
certainly worth a try for starters. If that doesn't work then i guess ya gotta dig a bit deeper. I'm not sure if compression would be directly related to smog or not...May just make your cat work harder to burn every thing up...
KrashDH is offline
Old 06-01-2009, 09:19 PM   #5 (permalink)
start w/ the leak down to determine where the problem actually is. You could have a burned valve, you could have some carbon stuck to the valve, not letting it seat 100%, you could have a bent valve, you could have a bad ring, you could have a leaking head gasket, i could go on, but you need to determine where the lost compression is going. Once you figure that out, you can move on to figuring out the best course of repair.
__________________
2000 4runner w/ a few changes
Stick_Figure is offline
Old 06-02-2009, 06:41 AM   #6 (permalink)
You might try seafoam before your complete tear down
sseaman is offline
Old 06-02-2009, 12:43 PM   #7 (permalink)
Quote:
id rather use water
__________________
tlo86 is offline
Old 06-02-2009, 02:00 PM   #8 (permalink)
hross14's Avatar
Stick_Figure--is Spot on. There is no cure in a can (for the most part)
Leak Down!!! and listen to see where the leak is coming from. Air out the intake--bad valve. Air out the exhaust=bad rings.
You can also squirt some oil in the hole during the test and see if that improves the PSI reading (NOT ALOT either). If it does your rings and probably the problem. No easy way around it.
__________________
Yes, I said "country." America really is a nation, but you couldn't convince those who lead the Democratic and Republican Parties of that. Both parties now see America as nothing more than an economy, a marketplace, and not a sovereign nation. They don't see you and me as citizens of this great nation; they see us as units of labor, consumers and taxpayers.
Yes, I am here to collect my 238$ worth of stock from AIG.
"What do you mean a free market economy doesnt apply to the rich?"
hross14 is offline
Old 06-12-2009, 09:23 PM   #9 (permalink)
Threadstarter [OP]
Valves were out of spec. My mechanic adjusted 5 exhaust valves for being tight and even though there are 16 different shims, only four are for when they get tight. I know on at least one that there is no more adjustement after this. I wonder why they are wearing so fast for as much as I take care of the truck? How much longer till I need a valve job?, maybe another 80k?
I'm bummed out that I'm having to think of when to sell the truck before a valve job or just do it and keep the truck? A newer truck with maybe a V6?
Old 06-15-2009, 07:35 AM   #10 (permalink)
hross14's Avatar
motorcycles have this same problem (valves being tight). I have only seen this on a 22RE with over 500k. Not sure of the exact factors that cause it though..... theory suggestest either the valves stretch or the seats are beaten further into the head???
__________________
hross14 is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
2000, 27, 27l, 4cyl, 4runners, 95, check, chevron, engine, engjne, light, misfire, shims, tacoma, techron, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
4cyl engine problem mbuck 86-95 Trucks & 4Runners 19 09-02-2012 03:17 AM
More ?s auto black 904runner 4cyl SR5 engine into an manual red 85 4runner 4cyl SR5 dirtymuddtrucks General Vehicle Related Topics (Non Year Related) 1 04-07-2009 08:41 AM
How to check the gearing on 4x4 - 86 IFS 4cyl mnmontana 86-95 Trucks & 4Runners 7 10-29-2008 05:40 PM
Noisy 4cyl engine!! cstem 95.5-2004 Tacomas & 96-2002 4Runners 6 07-14-2005 08:38 PM
need info on engine swap(v6 to 4cyl) ROCKRUNNER 95.5-2004 Tacomas & 96-2002 4Runners 10 04-11-2003 06:03 PM
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
