Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
cheap shock trick for 2nd gen. 4runners
Just thought id pass this along. I just installed 1.5" coils in the rear of my 93 runner. I wanted to go with rancho shocks so I bought the ones listed for my truck. They say they are good for 1-2" of lift. Well thats a load of crap they turned out to be exactly the same length as the stock ones. So that is the only listing they had for that style shock(stud mount at the top and eye at the bottom) The next size up is 4" longer which would have it almost bottomed out at sitting on level ground, not very good for offroad. The new rancho would only allow for 1" of drop before maxing out. So I pondered what to do and this is what I came up with. I took a piece of 3x3 box tubing, cut it 3" long. Drilled a hole in the top to match the size of the hole in the shock mount, then drilled a hole to match where the shock stud goes through, then bolt it to the mount off the frame Basically i extended the mount down 3". Now I have flexed this setup out and at full flex you can undo the shock pull it off the axle so the shock is at full drop but so is the axle, and when the wheel is stuffed right up into the wheelwell the shock bottoms out right when the rubber bumpstop starts to compress, so it actually works pretty good. This setup will allow for the use of stock shocks if you wish. Or any aftermarket shocks listed for the stock runner .Well thought id pass this cheap trick along and hope it helps anyone save a few bucks.
__________________
"You either make it or break it!!!" 91 runner, v6, 33" BFG muds, welded rear end, ranchos, 1.5 coils, hd bumpers |
| Sponsored Links |
#2 (permalink) |
Cool idea, I'll have to try that. Sounds a lot cheaper than buying new shocks.
Steve
__________________
Steve. '93 4Runner V6 Auto 4x4 Robinhood's Lair. || Gettin' Off 4wd Club member Lots for sale:5.29 ARB IFS third member... Click Sierra Club policy: [A reason to close trails] ...Physical soil damage, often readily visible, resulting in: a. Erosion, causing soil loss and damage to stream banks, streams, and fish habitat... Lesson...Stay on the TRAIL! |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Super cheap trick for 3C Maglite holder | Tacoclimber | 95.5-2004 Tacomas & 96-2002 4Runners | 18 | 04-26-2006 12:39 PM |
| Removing CV axles on 2nd gen..whats the trick ?? | nrgetic99 | 95.5-2004 Tacomas & 96-2002 4Runners | 28 | 10-13-2005 01:18 PM |
| Cheap trick by removing an acessory | fo_runner | 95.5-2004 Tacomas & 96-2002 4Runners | 16 | 06-25-2005 06:26 AM |
| hi-lift cheap trick | shiftless89 | Offroad Tech | 1 | 05-02-2005 11:48 AM |
