cheap fan controller
Old 12-06-2005, 07:27 AM
abalagtas's Avatar
I'm pretty sure the dealer screwed up the fan controller on my Flex-a-lite the last time they touched it doing my timing belt. They shorted it out some how on the A/C idle up relay. If I connect it and the fan kits in, my A/C shorts out and I have to replace the 10am fuse behind the glove box. After that, the A/C turns on only when the fan is running.
FAL wants $56 for a new board.
DC controller is $109.
Is there a cheaper/reliable controller than the FAL?
BTW. I haven't had any problems with the FAL that wasn't user error. Other cooling problems I may have wanted to blame on the fan, where really weak areas in other parts of the cooling system....ie Radiator.
Old 12-06-2005, 07:39 AM
Marc's Avatar
The Hayden 3652 works well.
Old 12-06-2005, 07:48 AM
bamachem's Avatar
pull your entire controller and wiring out and reinstall after a good inspection. it may be something that you can fix easily.
i wouldn't be confortable w/ the cheapest controller you can find since you will overheat if it fails.
Old 12-06-2005, 12:17 PM
abalagtas's Avatar
Not really going for cheap in quality, but cheap in price.
How much is the Hayden 3652 and can I pick it up at an auto parts store.
I don't really want to sink $$ into a FAL replacement since it got mucked up so easily by the dealer.
I'm going to try and fix the PCB, but wanted a replacement on-hand before I started. It's been a while since I've had to solder on a board....like 20yrs
Old 12-06-2005, 12:27 PM
garrett1478's Avatar
if you feel like paying for it, the DC controller bamachem used is good because of the variable speed rather than on/off.
Old 12-06-2005, 04:22 PM
abalagtas's Avatar
Ok...just picked this up and was looking through the instructions. Do you actually put the probe all the way through the radiator? I didn't realize you could seperate the fins. I will probably hook up a manual switch instead of the A/C power up.
Marsheen
02-17-2016 12:29 PM
coryc85
09-09-2015 06:24 AM
93runner223
08-31-2015 07:14 PM
1996Taco
07-20-2015 12:02 AM
cyclist231
07-07-2015 12:56 PM
Quick Reply: cheap fan controller
