Chassis/firewall to engine block ground?
Old 12-27-2014, 07:02 AM
ThorInc's Avatar
Have Googled this as well as searched on this site; looks like I have a 9-12" -ve ground from mid passenger side of top engine compartment firewall to engine block at level of spark plugs? Is this a -ve ground?
1997 4runner sr5 5 speed 3.4L....
Old 12-27-2014, 10:07 AM
rworegon's Avatar
Yes, that is a OEM ground location for the 5vz-fe.
Old 12-27-2014, 10:09 AM
wyoming9's Avatar
Red face
The ECM ground goes to a manifold bolt on the right side of the engine .
I am really not sure just what your trying to ask.
I run the grounds off the battery one to the inner fender
one to the cast steel engine block
one to the frame because I have a habit from doing trailer lights..
I make my own to what ever length they need to be.
Then you have the list of ground points for all the minor electrical circuits
I have seen these kits on Ebay with a whole bunch of extra grounds for what ever reason .
Old 12-27-2014, 10:27 AM
ThorInc's Avatar
Was trying to ascertain if this was the spark plug ground, a radio ground or what exactly was being grounded. I cleaned them up and will replace that wire with heavier gauge, that is one puny length of wire. Tricky to reach the bolt on the back of the block....
bigjstang
08-25-2021 12:41 AM
Doug4320
03-24-2018 10:11 PM
razorman8669
07-12-2015 12:13 PM
jon.r
07-11-2015 03:34 PM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: Chassis/firewall to engine block ground?
