Charcoal Canister
its behind your rear axle right in the middle under your spare. remove your spare and its easy to access....shouldnt be that hard to replace...BUT...those canisters are bloody expensive (try to find used one)!!!
-B
-B
Hello, Dianna ... I'll second "4Crawler's" suggestion on this as it is pretty easy to do & if you managed to get those rear shocks off (did you???), you can definitely handle this tiny bit of maintenance up keep.
That is , unless it's a sealed unit, I'm not sure.
No way to service, just replace.
Originally Posted by callmej75
Anyone know how to clean the charcoal canister on 2nd gens?
I'll try again tomorrow.
Cannister is sealed and filled with charcoal. Part of the fuel tank evaporative emissions control system. Fill gas tank w/ cold gas from underground tank, park truck in the hot sun, gas in tank expands and forces fumes out. Cannister is in the tank vent, charcoal absorbs the fumes. Then later when the engine is running, vacuum is pulled on the cannister to suck the fumes out into the intake, where they are burned.
To clean, pull cannister out, plug the Purge port and blow ~40 psi compressed air into the tank port, dust and dirt should flow out the vent port on the bottom.
How can you tell if one is "bad" or needs to be cleaned? Sould it part of a PM routine?
To be honest, I learned my truck has a new part today
Factory Service Manual will have the full test/clean instructions. On my '85, it says blow low pressure air into the tank port, make sure it flows out the purge and vent ports. Then blow into the purge port and no air should come out the other ports. Suppose you would see liquid come out if it was saturated. Cleaning might help.
Originally Posted by jimabena74
thats why they tell you to not to top off the tank...
i have a truck with a 22r... where is my charcoal cannister.... and 40 psi, can i push more through it?
justdifferentials
Just Differentials
06-13-2022 07:40 PM
kawazx636
10-06-2021 03:03 PM
WTB[PacNorWest]: WTB - Tacoma/4runner 3.4 Charcoal canister and igniter
94whiterunner
07-12-2015 07:15 PM
