changing fuel filter, help!
ok. according to this article http://www.4x4wire.com/toyota/mainte...6/fuel_filter/ it says i can pull the fuel pump fuse. where the bejesus is that!??!?!
95 4runner
3.0l v6
auto
4x2
help pleaseeee
95 4runner
3.0l v6
auto
4x2
help pleaseeee
I change my filter every 30,000 miles and I've never pulled this fuse. What I do is open the gas cap to relieve any pressure in the tank and then slowly loosen the lines going into the filter. A small amount of gasoline will trickle out as you crack open the first line, so just place a little bucket below the filter. After a minute or two it'll have drained and you can remove the filter. No big deal.
the filter decided it just didnt want to come off. i didnt want to round off the nuts, so im just gonna bite the bullet, bend over, grab some ky or astroglide, and let toyota do it
what about trying some liquid wrench or something? whatever they do to get it off you most likely can as well.
and when i changed my fuel filter, i didn't pull any fuse either.
Liquid wrench overnight, then grab the filter with your hand while a wrench is on one side and just reef on it. You'll get 'er.
I was just talking to someone today about how much of a PITA it is
