Changing coolant
Changing coolant
I need to change coolant in 02 4 runner 2WD, I will use Toyota Red coolant, I mixed 50/50 with water . which is the correct way to change it ? Please give me some inputs.
Thanks.
Thanks.
Somebody out there ?
How do I avoid overheating ? someone out there ?
Louis,
Please use the search function provided here before posting new. A search for "coolant" or "overheating" gives many threads that could help you.
Here's one:
https://www.yotatech.com/forums/f120/coolant-problems-104102/
There's also a Newbie Tech Section that will help you a lot:
BTW, this is posted in the wrong category for your year Yota... Good luck!!
Here's one:
Louis,
Here's one:
https://www.yotatech.com/forums/showthread.php?t=104102
https://www.yotatech.com/forums/forumdisplay.php?f=120
Here's one:
Its posted in teh correct section, he did say 02 4runner
But yeah, the search will bring up many things that will help you out.
Yeah, I squeeze the upper rad hose a few times to work out the bubbles. Buy some Prestone flush and follow the instructions on the back to do everything. By the way, you can use GM Dexcool - which Wal Mart carries - to do the change. They have the best price. Be sure to use distilled water too.
the1998sr5
15
07-14-2020 08:35 PM
WellsR
12
07-31-2015 03:27 PM
itzmywife's
07-25-2015 04:55 PM
the1998sr5
07-16-2015 06:20 AM
