changing belts in a 02..
Old 09-29-2009, 05:05 PM
burton6509's Avatar
need to replace them and i was wondering if there is a thread on how to change these out.... i will be replacing all 3 belts i would like to know how to do this for the future.
any info would be great!!
Old 09-29-2009, 05:12 PM
24Runna's Avatar
Pretty simple. If it is anything like my '95. Undo the radiator shroud, undo the fan, loosen bolts so there is some slack in the belts (PS, Alt, and A/C). Put the new ones on, tighten up the tension but not too much other wise it will just stretch out. Then repeat everything backwards and start her up!
If you need help try searching, or if you can't find the answer post here.
Good luck!
Old 09-29-2009, 08:04 PM
eric-the-red's Avatar
For the alternator belt loosen the mounting bolts, swing the alternator towards the block and remove the belt. Reverse to install. For the A/C belt you'll need to remove the skid plate to get to the tensioner, it's underneath. Loosen the lock bolt and screw the tensioner bolt in until it gets loose and the belt comes off, and reverse to install. For the power steering the tensioner is under the power steering pump, it works the same way as the A/C one. It's easier to reach if you remove the air box, but can be done without.
There's a link to an FSM for 96-02 4Runners about half way down this page, that might help with diagrams
http://www.ncttora.com/fsm/index.html
Old 10-01-2009, 06:43 AM
stir_fry_boy's Avatar
I did it not having a manual in about 2 hours not trying to "bust it out". I also drained my coolant and removed my upper radiator hose. That made it easier. It was not bad at all. When I put it back together, I used a long screwdriver put between 2 nuts holding the fan on to keep it from rotating while I tightened the rest of the nuts up, then it just rotated it switching between all 4 nuts going around till all were tight.
When is the timing belt due? If you are going to do it soon, just wait and do it then.
WellsR
12
07-31-2015 03:27 PM
cgilley
07-25-2015 10:55 PM
dinks07
07-15-2015 05:34 PM
nick b
07-11-2015 04:38 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: changing belts in a 02..
