Changing axle shafts
Old 07-27-2003, 06:02 PM
93toy's Avatar
A read a post (on this site) the other day where someone said it was just as easy (or easier) to change the entire axle shafts as what it was to replace a torn boot. Well, I picked up the lifetime warranty axle shafts from Autozone but I have a question before I tear into it....the Haynes manual says you have to rip into the manual locking hub to remove the outboard end of the shaft, is this true? I know there are 6 bolts for the inboard end, but can anyone offer any detail as to what's involved with the outboard? Any help would be appreciated.
Old 07-27-2003, 06:49 PM
keisur's Avatar
Re: Changing axle shafts
very interesting.
metal22lica's Avatar
you do have to take off your hubs and take off an snap ring that hold the shaft into the hub/wheel assembly..
Old 07-27-2003, 09:52 PM
Firefyter-Emt's Avatar
Yup, easy to yank the hub.. Remove that c-clip. Now here is another tip, Unblot the lower ball joint at the control arm (just 4 standard bolts) this will not harm the ball joint and it gives you plenty of room to work with, BTW, I left the stock bolts just the way they were.. Some people hammer them out to make swaps eaiser.. I think it is a lot eaiser to remove the 4 bolts at the ball joint. Also, lock the hubs and before you jack it up, break the nuts to the shaft free first.
Old 07-07-2008, 03:42 PM
highridinyota's Avatar
hes got it down to a science.easiest way ive found
Old 07-08-2008, 04:33 AM
toy_tek's Avatar
This thread is so old the OP has a 3rd gen in his sig now.
Flying91
45
04-11-2024 04:39 PM
polo451
13
11-20-2016 07:49 PM
A2theK
01-10-2016 10:18 AM
88sasturbotoy
08-11-2015 01:56 AM
Backcountry411
07-24-2015 08:06 AM
Quick Reply: Changing axle shafts
