changing antifreeze
changing antifreeze
i am looking in my Haynes manual and it says to remove the radiator drain plug and an engine block drain plug...... I don't remember removing the engine block drain plug last time..... is this needed and if so where is it??? thanks
This picture was taken from the passenger side wheel well, it shows the block drain port, the drain bolt is right above it. Install some tubing on the drain port, route it into a bucket, then turn the drain bolt until the coolant flows out the tubing.
Picture with the tube installed on the port with the drain bolt above it.
Yotadawgjr
10
08-23-2015 10:51 AM
