Changed my filter brand...WOW.
Well, recently I read a website somewhere (now I can't find it) about a guy who was independantly testing all of the oil filters on the market. His conclusions were that Fram oil filters were crap. This is all I have used on my vehicles for the past 15 years, with the exception of the vehicles I had that Fram did not make a filter for.
After reading that website, I decided to try something different. My truck has 158,000 miles on it, and has had the infamous 2.2 startup rattle since I bought it. So last weekend, I brought home 5 quarts of 10w30 Castrol and a genuine Toyota oil filter... just for kicks.
The startup rattle is gone.
I am sold... no more Fram for me. Unbelieveable that a $5 part could make that much difference.
Oh yeah, if you know the website of which I speak, and happen to have it bookmarked... a link to it would be HUGELY appreciated.
~Wade
~Wade
I found a couple of filter test reports... Do any of these look familiar?
Mark
- http://www.pajero.dn.ru/oiltest.html
(from July 1995) - http://www.frankhunt.com/FRANK/corve...lterstudy.html
(June 2000. there are many copies of this report on the net, this looks like the original) - http://www.frankhunt.com/FRANK/corve...ilfilters.html
(personal commentary on the above report) - http://kozmik.guelph.on.ca/gtdprojec...il_filters.htm
(a page of links to reports)
Mark
Whats this startup rattle you speak of? I have an 1989 4Runner with 165,000 miles on it, but don't know of any rattle.....
I do use a Toyota Oil filter most of the time - actually doing an oil change tomorrow night. Goin' with Mobil 1 Syn and Toyota Oil filter.
Originally posted by mpulver
That's a snatch of the Russ W. Knize study... it's all over the 'net. Some folks even put it up and removed his copyright notice.
C
Yep, it was the mini mopar one. I read that whole thing, and wow, talk about some information.
2.2 startup rattle seems to be pretty common. Check a few of the threads out about it, and you will see what I am talking about.
If a simple filter change solved a startup rattle, it may have to do with the design of the filter's anti-drainback valve or lack thereof. Supposedly the TOY filters are very good in this regard. I only use OEM filters. They're not that expensive if you wait for the occasional 2 for $7 sales at the stealership.
However, rattling on startup ain't normal, even if the oil did drain out of the filter, as long as the truck hasn't sat parked for weeks on end. And what would a "2.2 rattle problem" be? I'm guessing you mean 2.4, since 2.4L would be the displacement of the 22RE which I assume is what's in your '88 (?) Startup rattle can be indicative of impending timing chain disaster in these engines, so if the rattle sounds like anything more than typical 22RE valve chatter it may behoove you to pull the valve cover and make sure your timing chain guides are still intact. The t-chain can make a rattle on startup for a few seconds while it's eating into your timing cover.
Now that I think about it, I suppose the anti-drainback function of an oil filter could be related to t-chain rattle: the chain tensioner is driven by oil pressure, so a lack of oil pressure at startup (from an empty filter) could leave the chain a little slack, hence the rattle.
How long since you bought the truck? Might wanna give the t-chain guides a look-see. Not trying to worry you, but you can't be too careful and it only takes fifteen minutes. Of course, if I am mistaken and you have the V6, none of this applies! I just took a guess based on that 2.2 number.
Fram is CRAP CRAP CRAP CRAP CRAP!!!!
Did I mention that Fram is CRAP?
Toyota makes good filters, nothing wrong with using them. As for oil, Mobil-1 is damn nice, Castrol is probably just under that. (Note - my oil experience between the two is based on motorcycles, YMMV with cars). Personally I will be switching to Amsoil (real soon, after reading that if you use injector cleaner you should change oil within 500 miles!) after running a bottle of their engine cleaner through...
Originally posted by GV27
Actually the MiniMopar link is the original. MiniMopar.net is Russ' page.
Mark
I just replaced my timing chain/guides etc.. a couple of months ago and I still get the start-up rattle using OEM filter. Apparently the t-chaing tensioner is the first thing to get/need oil which is why it rattles.
I've also heard Toyota oil filters are hit and miss when it comes to a properly functioning anti-drain back valve so hopefully this explains my rattle.
Warren
Warren
I have been using Castrol GTX 10W-30 and OEM filters (air too) since day one. I change every 3,000 miles or close to it without fail. The Taco is about 5 1/2 yrs old now with 94K miles and right after I change the oil, it is so clean that you can barely see it on the dipstick. After a good 3,000 miles, it is still a nice honey color. I am also not afraid to change my air filter more often than not, especially after alot of dusty trail excursions. It's worth the extra cost to me, to be a little overkill rather than let the engine suffer. I use the OEM paper filters and feel really good knowing they are not letting any crap get through. I'll be getting the oil analysis done for my 100K celebration, and I'll be sure to post the results.
I buy my filters at a good price from this place (especially good deal if you stock up and save on shipping)...
http://www.toyotapartsworld.com/toypartpage.htm
$10.99 for air filters and $3.29 for oil filters
Posted by Skydigger
Now the Runner has about over 90K miles and still runs smooth and quiet. I like the combination of synthetic oil and OEM filter.
Noel
I'm getting my first oil change on my '03 V8 Runner on Friday. What oil (brand, type, everything) should I take in, or should I just let them use their oil? What about the filter? Same question. Yes, I'm letting the dealer do it while it's under warranty.
Warren
Originally posted by BajaTaco
I have been using Castrol GTX 10W-30 and OEM filters (air too) since day one. I change every 3,000 miles or close to it without fail. The Taco is about 5 1/2 yrs old now with 94K miles and right after I change the oil, it is so clean that you can barely see it on the dipstick. After a good 3,000 miles, it is still a nice honey ... ... $10.99 for air filters and $3.29 for oil filters
