Champion vs Nippondenso Spark plugs
Old 10-03-2006, 06:04 AM
arrowhead's Avatar
The plugs at question are Champion and Nippondenso. The Champs are single prong and the Nips are dual prong. Took out the Champs and installed Nips dual prong and truck runs much better. My question is this. The book says to gap the plugs at .043, but the guy at the dealership said NO!, put them at .032. I left them at .043. What should they be at?
Arrowhead
Old 10-03-2006, 06:26 AM
MTL_4runner's Avatar
You should not use single electrode plugs unless they are iridium plugs.
They should be fine without gapping but when in doubt, owner's manual is correct.
......I visually inspect each plug but never gap them.
Old 10-03-2006, 06:37 AM
HarrisonP's Avatar
I made the mistake of running champions when I first got my 4Runner and it had a horrible misfire. I have been running either Denso or NGK ever since (the double electrode plugs).
Old 10-03-2006, 06:46 AM
cooper4x4's Avatar
3.4L should be gapped to .043. Buy the plugs from the dealer. The dealer says that they come pregapped but they do not.
Old 10-03-2006, 07:39 AM
Elton's Avatar
Originally Posted by arrowhead
The plugs at question are Champion and denso. The Champs are single prong and the denso's are dual prong. Took out the Champs and installed denso's dual prong and truck runs much better
hmmm i wonder why lol could be you should only use denso or ngk
.... also i didint gap my plugs from the dealer and never had any problems i would of gapped them but not sure how you can
Old 10-04-2006, 01:47 AM
grimpy's Avatar
I found a post in which someone emailed NGK asking about gapping the dual electrodes and they said not to... Here is the link to the post... https://www.yotatech.com/forums/show...9&postcount=23
Might be just for NGK's... Just leave it as it came...
Old 10-04-2006, 05:15 AM
Rock Slide's Avatar
I've heard the same thing from Dealers...they've always told me they should be gapped to .032
Old 10-04-2006, 05:41 AM
I wonder if that is the same as them saying the crank pulley bolt should be torqued to 184 ft-lbs?!
The owner's manual has the correct specs for gapping.
montanatruck
02-26-2017 07:07 AM
raptor510
02-17-2017 07:11 AM
raptor510
08-19-2015 02:15 PM
accuracy
08-04-2015 08:05 PM
defrag4
07-31-2015 10:50 AM
Quick Reply: Champion vs Nippondenso Spark plugs
