Center Console Removal
I'm installing a CD changer and I need to get to the radio cassette controller. Does anyone knows of center console removal documentation for the 3rd generation model? So I can do it safely? Thanks in advance...
Pull the e-brake up. Remove the screw on each side. Remove the two bolts inside on the bottom. You might need to pry up the shifter trim piece. I think that's it.
Jim
Jim
You also need to pry out the panel by the fan controls. Then you need to remove the phillips screws. Now you can pull the whole thing out. Dont forget to unplug everything from the back once it is pulled out.
https://www.yotatech.com/~corey/tech/slc_stereo/slc.htm
i know it's for the early 3rd gens, but it shouldn't vary that much...good luck
justdifferentials
Just Differentials
14
09-24-2017 08:32 PM
terminator
07-27-2015 07:13 PM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
HookahRoo
07-20-2015 07:06 PM
