center console cup mod installation problem
Hey guys, I am trying to do the cup holder mod. I got a 99 console, the e-brake handle, the mounting plate for both the e-brake and console. From what I read on yotatech, it should be a direct swap. But for some reason the new e-brake mounting plate would not align to the mounting hole, is like half a cm away. It looks like the square opening for the e-brake mounting plate on my 96 is not as big as the 99 and up model. It is so weird, I wonder if 99 and 00 or 02 has a different mounting plate since I am not sure which model I got. I was all excited to install them just now and I am like now. Please help please help!!! Thanks in advance!!
My best suggestion is to use your 96 ebrake. I used my 97, unbolt, twist, dril and rebolt. It really wasn't that difficult. The only trouble I had was lining up the silver bracket.
Thanks guys!! I thought it would be a direct bolt on thing since I got everything form the yard. I might just use the original e-brake plate or grind some part of the hole to make the new e-brake mounting plate fit.
Edited, because i'm a moron...
The two mounting brackets should be the same, i put a 99 console in my 96, and WT put an 01 console into his 98 (ithink) Got pics?
Steve
Originally Posted by NorCalVP
Are you talking about the metal bracket that the rear of the console bolts to? if so they yes they are different, but the 99-00 (looks similar to the 96 bracket but is a little shorter) will bolt up, and the 01-02 bracket (it's gold and has a bunch of other stuff on it) will bolt up too. Compare it to your 96 bracket, maybe the yard sent you the wrong bracket.....
Steve
Steve
Hey guys, know what!! I found the solution!!! I just reuse my 96 e-brake mounting plate and the 99 e-brake and it bolt right on. I just need to remove the small metal holder for the e-brake cable and it works flawlessly!!! So actually we can reuse the old e-brake mounting plate, a 99 console and its mounting bracket, and a 99 e-brake handle and we are set!!!! I am happy now!!
Original 96 e-brake mounting plate and 99 e-brake handle
http://photobucket.com/albums/v497/h...t=IMGP0514.jpg
Finished product!!!
http://photobucket.com/albums/v497/h...t=IMGP0515.jpg
Finished product!!!
Ahh yes I have a 96' not a 98'
and sorry for being late seeeing this I did re-use my old bracket you are refering to since the newer one was off a little I looked through some older pics and it jogged my memmory since its been well over a year ago.
here a pic.... Left is the newer and the right is the 96'
Finished product!!!
Finished product!!!
Now you are a member in the elite 99+ console mod club!
icentropy
07-11-2015 07:21 AM
tpd143
07-07-2015 09:06 AM
