Cel Help
Old 11-16-2007, 12:09 PM
H82BL8's Avatar
Cel Help
I got a CEL and had the codes checked and they came back P0133 & P0130 which both pointed to the O2 sensor, but after apporx. 75 miles the CEL went out. The vehicle was drivng fine and the I noticed at about 50-60 mph I have hesitation and stuttering. If I increase acceleration a lot the hesitation is gone. O2 sensor??? Coil pack??? Any suggestions.
Old 11-16-2007, 05:02 PM
MTL_4runner's Avatar
Yes, Bank 1, Sensor 1 is the O2 sensor located closest to the engine before the converter.
Here's the writeup:
http://www.4runners.org/articles/02sensor/
$89 dollars OEM denso sensor http://www.urdusa.com/product_info.p...s_id=430006000
Old 11-16-2007, 10:01 PM
98runner210's Avatar
Sorry if this sounds rude but if it is giving you an O2 sensor code then I would think that it has something to do with your O2 sensor. That is unless you have a bad cat.
Ronnyboy
02-11-2016 05:57 PM
Sam hain
19
09-30-2015 08:25 AM
charlie_fong
09-27-2015 10:06 PM
Draven023
09-26-2015 12:41 PM
256mbaker
07-31-2015 06:45 PM
Quick Reply: Cel Help
