CEL code 1153
CEL code 1153
ok, yes i did search, and NO there is no info besides the list of codes that comes up.
here is what the codes list says:
P1153 Bank 2 Fuel Control Shifted Lean
P1153 A./F Sensor Circuit Response Malfunction
this code came up after my transmission was put back in.
any theories?
any theories?
That's a very odd code because there is no bank 2 on your 4runner (hence no info when you searched YT).
Did you pull the negative battery terminal after you installed the tranny?
If not, try it and then see if the code returns.
charlie_fong
09-27-2015 10:06 PM
Odin
09-26-2015 06:56 PM
