cel 1135 2001 4runner it's not the MAF
The wife's 4runner is lighting up the dashboard. I ran the code and it came back as 1135. By searching on here, some say it's the MAF and some say the o2 sensor.
The maf in my es300 is the same as the 4runner so i swapped it and she is still getting the code. So it's the o2 sensor. But which one. Most of these vehicles have 2, 3, or 4 o2 sensors.
Anyone know exactly which one it is?
the stealership says it's part# 89465-39835 and that it's stamped on the sensor. I'll have to check when i get home if it's stamped on. 1st, i'll need to locate it.......
Just so you know, by 2001 there were no more Cali. models, or, more precisely, all models for all states used the two-cat system with the air/fuel sensors before the cat that was previously the 'California' emissions system up through 2000. 234-9002 is the correct A/F (front) sensor for your truck. Buy some new nuts from the dealer unless you are sure yours are good; most of us have needed them. Tip: Amazon has a pretty good price on this sensor.
Code 1135
My 2002 4runner had the same code twice. The check engine light went off after only 20 miles each time and it runs fine. The first time it came on was when I towed my pop-up for the first time and then went off. The second time was when I was stuck and spinned alittle on some ice and then went back off. My mechanic said I should replace it but it will cost about $200. What do you guys think? Any input would be great. Thanks
06-01-2021 01:51 PM
mengquis
07-13-2015 10:39 AM
