cel 1135 2001 4runner it's not the MAF
Old 04-02-2010, 12:24 PM
dallison's Avatar
The wife's 4runner is lighting up the dashboard. I ran the code and it came back as 1135. By searching on here, some say it's the MAF and some say the o2 sensor.
The maf in my es300 is the same as the 4runner so i swapped it and she is still getting the code. So it's the o2 sensor. But which one. Most of these vehicles have 2, 3, or 4 o2 sensors.
Anyone know exactly which one it is?
Old 04-02-2010, 12:35 PM
yotaman85's Avatar
most likely before the cat.
Old 04-02-2010, 04:01 PM
dallison's Avatar
that's what i was thinking, now to locate a good cheap replacement
Old 04-03-2010, 12:52 PM
dallison's Avatar
234-9002 seems to be the correct part # for the denso front o2 sensor for non cali.
Does anyone have the toyota part #?
Old 04-05-2010, 06:34 AM
dallison's Avatar
the stealership says it's part# 89465-39835 and that it's stamped on the sensor. I'll have to check when i get home if it's stamped on. 1st, i'll need to locate it.......
Old 04-05-2010, 07:44 AM
TheDurk's Avatar
Just so you know, by 2001 there were no more Cali. models, or, more precisely, all models for all states used the two-cat system with the air/fuel sensors before the cat that was previously the 'California' emissions system up through 2000. 234-9002 is the correct A/F (front) sensor for your truck. Buy some new nuts from the dealer unless you are sure yours are good; most of us have needed them. Tip: Amazon has a pretty good price on this sensor.
Old 04-05-2010, 08:48 AM
BigBallsMcFalls's Avatar
1135 is bad heater in an air fuel sensor
this is the front sensor, before the cat
as indicated, obtain new nuts and also a gasket
Old 04-05-2010, 11:46 AM
dallison's Avatar
you guys kick ass! i'll wd-40 the out of them and hopefully i can salvage the nuts.
Old 04-05-2010, 12:52 PM
Kerby J's Avatar
pb blaster works better
Old 04-05-2010, 01:31 PM
FogRunner's Avatar
Be sure to put a little Anti-seize on the nuts and bolts. It will make it allot easier if you ever have to swap it out again.
FOG
Old 04-05-2010, 03:20 PM
TheDurk's Avatar
If you get the Denso sensor from URD or Amazon, it should come with a new gasket (but no nuts).
Old 04-07-2010, 07:13 AM
dallison's Avatar
ordered the sensor and the nuts.
now i need to replace the oil pan gasket and figure out if its the transfer case that also has a leak
Old 04-09-2010, 12:14 PM
dallison's Avatar
the oxygen sensor nut part# is 90179-08059 and tehy are 2.13 ea
Old 04-10-2010, 01:25 PM
peacedog's Avatar
Code 1135
My 2002 4runner had the same code twice. The check engine light went off after only 20 miles each time and it runs fine. The first time it came on was when I towed my pop-up for the first time and then went off. The second time was when I was stuck and spinned alittle on some ice and then went back off. My mechanic said I should replace it but it will cost about $200. What do you guys think? Any input would be great. Thanks
Old 04-10-2010, 04:19 PM
dallison's Avatar
i'll let you know when i get the sensor and drive it. Amazon is taking their sweet time shipping it.
Old 04-10-2010, 04:21 PM
Cpate81's Avatar
SeaFoam DeepCreep
SeaFoam DeepCreep works pretty good too.
...and another SeaFoam use. Is there anything this stuff can't do??
Old 04-17-2010, 02:01 PM
dallison's Avatar
replaced the front o2 sensor and so far no codes. The wife usually would get a code w/in a few miles, so hopefully she's fixed.
Old 08-22-2010, 05:16 PM
dallison's Avatar
Four months later and no code. Fixed.
smthwsn357
12-04-2023 02:08 AM
06-01-2021 01:51 PM
Sandman
07-14-2015 12:36 PM
mengquis
07-13-2015 10:39 AM
Roger Borba II
07-09-2015 05:05 PM
Quick Reply: cel 1135 2001 4runner it's not the MAF
