YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 03-23-2004, 06:35 PM   #1 (permalink)
runnerboy97's Avatar
Send a message via AIM to runnerboy97
CB tuning
I finally got around to tuning my new antenna, i was gettin a little below 2 on the SWR meter. i know its a taste high, but the best i could get. I have a 3ft firestick with spring on the front bumper.
heres the mount, best pic i have so far.
__________________
1997 4runner,lifted, locked, dash and grille mounted red LED lights, its my DD
1988 4runner, SAS, dual lockers, dual cases, longfields, 36's, and lots more.
runnerboy97 is offline
Sponsored Links
To remove this ad, register today!
Old 03-23-2004, 06:38 PM   #2 (permalink)
shazaam's Avatar
Send a message via MSN to shazaam
You have the same set up as me. The problem is that its not ground properly on the metal. Remove the plastic between the spring and the bumper. So that it is metal contacting metal and that should fix your problem.
__________________
Experience is a hard teacher because she gives the test first, and the lesson afterwards.
<-- the artist formerly known as sdastg1
shazaam is offline
Old 03-23-2004, 06:45 PM   #3 (permalink)
what kinda of SWR are you getting? i might try removing the washer to see if that helps
__________________
Old 03-23-2004, 06:49 PM   #4 (permalink)
shazaam's Avatar
It was just reading hot, like 30+ .. if that makes sense. The needle just went all the way to the right no matter how much I tuned the antenna.
Then bumperis off right now, and while I was taking it off, the idea occured to me. So when I put it back on I'm going to try and remove the plastic washer and that should hopefully make the difference.
__________________
shazaam is offline
Old 03-23-2004, 07:04 PM   #5 (permalink)
i hope you mean around 3 not 30.
__________________
Old 03-23-2004, 07:55 PM   #6 (permalink)
Co-Founder/Administrator
Staff
Corey's Avatar
Carefull guy's, that washer is needed.
Been there done that.
The washer insulates the shaft as seen in the pic above.
That is what the coax wire is for.
One wire is ground which should be grounded by drilling a hole into your ARB or TJM bumper.
The other wire from the coax is on the ring that goes around the shaft of the antenna, and it must not come into contact with ground.
You can see also that the nut at the very bottom does not contact any ground of the frame or bumper as it is threaded on the shaft, and what keeps it from gounding is the bottom washer.
If any part of that shaft grounds, your SWR goes out the window.
I have a 1.1 or less match on all 40 channels.
Note also in the pic that it says the washers are for insulating.
In other words, they keep the shaft from grounding.
__________________
Corey
2007 FJ Cruiser
ARB bumper, Warn XD9000, OME lift, roof top tent, so much more, see my website & buildup thread
PNW FJ CruisersDetailing 101Join TopsitesMuffler ComparisonsMaggiolinas In The Wild
FJ Cruiser BuildupNew Roof Top TentVideo Of My PenthouseRehinge Your ARB/Engel Fridge
Corey is offline
Old 03-23-2004, 08:08 PM   #7 (permalink)
my stud mount only came with one nylon washer. Thats how firestick packaged it. Cory, does it make a difference if i have the kind of coax that jsut threads onto the end of the stud as opposed to the ring type end that you have?
__________________
Old 03-23-2004, 08:22 PM   #8 (permalink)
Staff
Corey's Avatar
I am not familiar with that type of coax you have.
I have heard of them, but I prefer old school methods when it comes to hooking up the antenna.
I like the two separate wires instead of that "Fire Ring" or whatever they call it.
One time I had the ground wire from the coax in the engine bay under a bolt next to the battery.
My SWR was terrible.
I ended up going to a local CB shop that carries the nice quick disconnect I have, and he told me the ground wire must be done within a few inches where it exits the sheath.
You can see mine here.
Corey is offline
Old 03-24-2004, 03:32 AM   #9 (permalink)
shazaam's Avatar
So what do we do if we have the wire that is screwed into the base of the spring. Its an all in one design. Only thing I can think of is to cut it and seperate out the black ground wire and attach that to the bumper. But then everyone tellls me not to cut the coax.
__________________
shazaam is offline
Old 03-24-2004, 06:09 AM   #10 (permalink)
the coax is this one
and the stud mount is this
i can live with the SWR just below 2, i was happy when i hooked up the meter and thats where it sat. everyone knows the bumper isnt the best place for an antenna.
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
cb radio poor signal, tuning? 91muddog 86-95 Trucks & 4Runners 33 08-20-2007 12:23 AM
3rd generation 4 Runner CB install and tuning BOSTON4RUNNER GPS & Communication 3 12-28-2006 10:32 PM
Please help with CB tuning paddlenbike 95.5-2004 Tacomas & 96-2002 4Runners 16 10-22-2003 10:31 PM
CB tuning dilema TDiddy 95.5-2004 Tacomas & 96-2002 4Runners 3 01-16-2003 01:46 PM
tuning cb antennas doink 95.5-2004 Tacomas & 96-2002 4Runners 2 01-03-2003 09:09 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
