Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
CB and scanners
Can they use the same antenna?
Since I already have a CB, I was wondering if I can use the same antenna to hook up a scanner?
__________________
2003 4runner SR5 4x4 Chaos Edition Chaos Edition! Operation Rebuild Chaos Edition Need to reach me or ask questions? You can find me here! |
| Sponsored Links |
#2 (permalink) |
The scanner has a different connector (BNC) If you can figure out a way to hook it up I dont see why not.
#3 (permalink) |
The radios will interfere with each other and if you try to key the CB, it will smoke the scanner.
When you hook both radios up, they effectively become part of the antenna system of the other. The CB will have a lousy match, so it won't be safe to use it and the scanner will have such lousy reception that it won't be worth it.
__________________
-Rob Slightly Modified 2001 Tacoma - WATRD.COM WATTORA Prez Tread Lightly certified Tread Trainer I don't work here anymore... In fact, I seldom visit anymore. You can find me via the links in my signature. |
#4 (permalink) |
thanks rob
![]() i guess that just means i'll have to use another antenna... hehe
__________________
#5 (permalink) |
I have a "Cellular look" glass mount antenna for my scanner. It is out of the way, and it works great. I have had it since I got my scanner a few years back. I got it at radio shack.
__________________
Rome the "Seafarinman" IT1(SW) US NAVY 1994 SAS 2RZ/R151F=244:1! http://s11.photobucket.com/albums/a176/seafarinman/ |
#6 (permalink) |
seafarinman:
how does the glass mount work? do you have a cable that feeds thru or is it done thru the glass? just trying to figure out the best way to use the scanner. thanks again fellas!
__________________
#7 (permalink) |
The "cellular" type antenna uses induction (magnetic I think) to send the signal through the glass. The outer part simply sticks on the outside and the inner part sicks to the inside of the glass behind the outer part. These work very well for the scanner since it is receive only.
__________________
#8 (permalink) |
Radio Shack sells glass mount ant. for scanners. They are fairly cheap in price and work well. I have currently have one installed.
__________________
92 4Runner SR5 Aisin hubs,pin stripe removed,police scanner,brush guard,Monroe Senseatrak shocks and steering stablizer,Brembo rotors,Downey HD coils,Blue reverse indiglo guages. . . http://community.webshots.com/user/sludg3 |
#9 (permalink) |
Yes they can use the same antenna.
You will need to get one specifically for that purpose and it will have a combiner box with it. These are special purpose antennas and are very expensive. Back in the day when I worked for the local Sheriff's Office I ran the entire telecommunications section. I set up the undercover cars with a special antenna that allowed the sheriff radio and cellular phone to use the same antenna. Not cheap. I might even still have a few of those laying around. Unfortuately they are the wrong bands for what you want otherwise I could hook you up with one. You would be better off just getting two antennas. I would be so much cheaper and the performance would be better also. Gadget www.GadgetOnline.com |
#10 (permalink) |
My scanner has the same connection as a am/fm radio. i just went to radiocrap and got a spliter for the wire. it only cost me about $7.00.
__________________
1985 TURBO 4Runner 22-RTE, 33x12.5R15 MT/R's, 1 Inch Shackles, Pro-Comp ES3000's, Trail Gear Sliders and 1 inch Wheel Spacers, FJ 62 Rotors, 87 Calipers, Cobra 18WX ST II, Custom K&N FIPK, Extended Diff Breathers, Custom Rear Swing-A-Way Bumper, Load Warrior with Hi-Lift, spare tire, 4 Hella 500's, 2 Pro Comp 55's for the rear, Addicted Off Road front bumper. |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Anyone play around with scanners need advice | paxil4x4 | Off Topic Talk | 0 | 03-22-2007 03:47 AM |
| Radio (Police) Scanners | amusement | Off Topic Talk | 9 | 11-30-2005 03:32 AM |
| Police Scanners | data | Off Topic Talk | 14 | 04-09-2005 07:49 PM |
| Police Scanners | pigcake | Off Topic Talk | 16 | 01-09-2005 07:28 AM |
