Catalytic Converter Removal
Old 11-10-2009, 02:34 PM
toyinhawaii's Avatar
Will removing the Cat. interfear with the A/F and O2 sensors operation to the point of makeing the ECM go haywire and make the truck run to lean or to rich
toyinhawaii is offline
Old 11-10-2009, 02:44 PM
mt_goat's Avatar
The A/F ratio sensor is before the cat/cats so I'd say no.
mt_goat is offline
Old 11-10-2009, 03:04 PM
Kiroshu's Avatar
Only if o2 sensors are after the cat.... if there is none then the cat will not effect it at all..... but if they are after cat then no....
Kiroshu is offline
Old 11-10-2009, 03:08 PM
buckz6319's Avatar
X2 on the answer NO....I don't have a cat and no problems
buckz6319 is offline
Old 11-10-2009, 05:36 PM
chad1041's Avatar
x3 on no i gutted mine out and put it back on runs and sounds great
chad1041 is offline
Jcrawl94
10
10-24-2015 04:34 PM
Griff
93-98 T100s (Build-Up Section)
09-23-2015 10:11 PM
09-04-2015 09:27 AM
Esibnitsud
07-30-2015 08:19 PM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: Catalytic Converter Removal
