Can't remove key from ignition - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 08-28-2007, 05:10 AM   #1
Baloo's Avatar
Had to go pick up a salvage car for my son yesterday to fix his Neon. He drove through a puddle in the recent heavy rains and bent a rod (don't ask). Rented a dolley and on our way to get it (dolley empty) we made a stop. When we came back out I could not get my 01 taco out of park. After a little work, was able to get it in gear and only used neutral the rest of the way up.
When we got where we were going, I decided toi risk it, and it appeared to work right with one exception. Now I can not turn the key all the way off which means I can not take the key out of the ignition. Anyone else run into this? Transmission? Shifter? Linkage?
Baloo is offline   Reply With Quote
Old 08-28-2007, 06:21 AM   #2
KZN185W's Avatar
maybe the shifter.
there's a white plastic linkage that will push a switch just infront of the shifter. try shifting back and forth a few times. if it doesn't work, open the upper console panel and check if the plastic linkage is engaging properly when the shifter is moved.
hth
KZN185W is offline   Reply With Quote
Old 08-28-2007, 07:06 AM   #3
bob200587's Avatar
See if you have a brake light out or a blown fuse. If the light is out, the transmission wont let it out of park because of some safety switch. It happened to my dad in his FJ80. If you were towing, a short in the trailer wiring could have caused a brake light to blow.
It sounds simple, but you should check before looking for more complex problems.
bob200587 is offline   Reply With Quote
Old 08-28-2007, 08:23 AM   #4
Baloo's Avatar
Bob and Roy, thanks,
Roy, I am sure that is now the problem because what ray described is exactly what happened but I did not relate the two at the time.
I am hoping when I got it into gear PRIOR to fixing the fuse I only damages the switch (plastic) and not something in the tranny.
Thanks guys.
Old 08-28-2007, 11:20 AM   #5
Baloo's Avatar
Parts guy is clueless so...until I get in there to take a look, I won't know what possible parts I need.
There goes my evening in front of the TV.
'90 4Runner strange radio problems theking11863 Vehicle Audio & Home Entertainment 2 03-19-2016 10:36 PM
ignition switch 94 4x4 PU redneck17 86-95 Trucks & 4Runners 1 08-05-2015 11:03 AM
Installed interior lights TDonkey 93-98 T100s 0 07-26-2015 11:14 AM
87 22R hi idle not kicking down until... luckypig44 Newbie Tech Section 4 07-19-2015 12:25 PM
91 Toyota pickup ignition switch, key will not turn!!?? Hamonacracker 86-95 Trucks & 4Runners 7 07-17-2015 09:33 AM
Tags
2003, 4runner, 96, cylinder, expedition, ignition, key, park, remove, sideways, stuck, tacoma, takoma, toyota, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
