can you carb the 3.0 engine ?
Old 11-04-2003, 01:35 PM
Question can you carb the 3.0 engine ?
hey there guys newbie here i was wondering if you can carb a 3.0 instead of the efi system i have now if you can where would i look in to buying the intake carb and what ever i would need (i love this little red thing )
im thinking of going the 7mge or 3.4 but don't know if they will work with my auto tranny it may need changing aswell ibought used it has about 142k on it but it idles rough at times and the codes are 25 and 26 one is for lean and the other is for rich don't what replace or where the efi fuse is located my cover for the fuse plane is gone
well if anyone can help me please send me help or you can email me or pm
thanks guys
duane
Old 11-04-2003, 02:25 PM
loosehead's Avatar
Welcome to the forum, Duane.
I doubt that there is an aftermarket carb manifold available. Personally, I think it would be a step backwards to put a carb on it...
With 142k on the clock, I bet the symptoms you describe are from clogged or dirty fuel injectors. Theres some info somewhere on here about sending them out to get them cleaned, maybe try a search...
Tell us a little more about the problems, a few more specifics about the truck, and what work you have already done, and I'd bet someone here could provide a little more insight into helping you get your vehicle running better.
Old 11-04-2003, 08:16 PM
MTL_4runner's Avatar
With that kind of mileage you should replace the O2 sensors.
You may need to do some work to figure out where the problem lies.
Don't go backwards and add a carb.....
Old 11-05-2003, 12:14 AM
rchavis's Avatar
Well, for the right amount of money you can. But why would you want to. As for your idle problem try BG 44 or Lube control fuel system cleaner or even Redline Fuel system cleaner. Change your O2 sensor. should only have 1.
Check to see if the headgasket campaign has been done. and ya may need to change the timing belt if it hasn't been done yet.
Oh sorry, I forgot, Welcome to yotatech. Glad to have ya aboard.
Old 11-05-2003, 06:51 AM
Scott72's Avatar
I would also take a look at your EGR valve. Mine went bad on my previous truck (1995 Chevy Tahoe) and it didn't idle well at all.
Old 11-05-2003, 07:01 AM
Arnold's Avatar
I think www.doaracingengines.com is coming out w/ a kit to convert the 3.0 to carb. It's in their "coming soon" section on the site. That said I wouldn't do it though because I hate carbs.
Old 11-05-2003, 09:05 AM
thanks guys for the input
well the runner has a4 to 6 inch lift with 32's and a flow master dual exit muffler and thats all i know about what been done to it
it has had a tune up with in the last 5k miles or so
should i get gears for the front and rear in the mid 4's or low 5's?
i think that would help the take of and downshifting problem
thanks
duane
Old 11-05-2003, 10:46 AM
mangoango's Avatar
Here's a quick chart.
Automatic tranny:
31" tires = 4.88
33" tires = 5.29
35" tires = 5.71
Manual tranny:
31" tires = 4.56
33" tires = 4.88
35" tires = 5.29
I wouldn't run 35" tires with the 3.0 & automatic tranny. You would be all show and no go. Know what I mean?
-mangoango
Old 11-05-2003, 11:24 AM
thanks dude what about the fuse panel cover under the dash can you tell what fuse is what? or where i can get the info
89 4 runner
duane
kazuya2416
04-05-2024 02:17 AM
Yota.Jay
07-23-2015 08:08 PM
ZONAYODA
07-13-2015 07:17 PM
Coreyr384
07-10-2015 11:13 AM
Roger Borba II
07-09-2015 05:05 PM
Quick Reply: can you carb the 3.0 engine ?
