Can worn out shocks/struts cause vibration above 65mph? HELP!
Old 04-10-2006, 08:41 AM
  #121
bdelc's Avatar
Is this the shop Matt?
A & R Tires Incorporated
(205) 674-6410
6518 W Jefferson Rd
Quinton, AL 35130
Old 04-10-2006, 03:22 PM
  #122
LSUMatt1514's Avatar
That's it. Don't be scared when you drive up and see the place. They do AWESOME work!!! Tell them Matt Averett sent you. I haven't been there in a year or so, but just mention my silver 4Runner (roof rack, vibration issues, etc.) and they'll remember me. I worked at the plant next door for almost 5 years. They're a really good bunch of guys. Family owned business for years. When I moved to the plant I'm at now, they were getting ready to expand. It's probably complete by now, so I may not recognize it if I saw it myself.
Matt
Old 04-10-2006, 07:41 PM
  #123
98runn'n's Avatar
Man, I have the same damn problem in my 98. As soon as i hit 65 mph then the vibrations hit. I'm sorry to hear it got the best of you, but I've even more scared of the fact that after this long thread the problem still persists. Hopefully, I can get to the bottom of mine and with any luck help you with yours. My quest begins next week after pay day.
Old 04-10-2006, 07:58 PM
  #124
Mr. Bob's Avatar
Man.... knock on wood... I feel lucky... I have 2 3/4" lift in the front of my 4runner, 1" diff drop, and I have 285s Cooper STTs that I ballanced using a reguair ballancer with no adaptors or anything... and I can go any speed from 0 - 100 MPH with ZERO vibration.....
Old 04-11-2006, 05:16 PM
  #125
Bob,
You are lucky. Very lucky. At this point, my only guess is the 265/75/16s. It's the only common denominator here. I never had these issues when I had 265/70/16s, but it makes no sense that it would cause this vibration. It's still there alright. There's one particular setup (ie when the tires are rotated a certain way) that it's better than normal, but of course that only comes around once every four rotations or so. It's getting damn aggravating. I can tell you that much, but I guess I've come to live with it even though it is driving me crazy.....still....so I guess I'm not used to it.
Matt
Old 09-07-2006, 06:38 AM
  #126
billie26's Avatar
Sorry for raising this post from the dead, but I have this exact same problem and have done all of the steps to pinpoint the problem. Nothing, and I still vibrate at 65mph +.
A classmate suggested that I can have my tires trued. Has anyone with vibrating problems tried this? I love my 4runner, as long as I don't have to drive it on the interstate.
edit: My 4runner specs:
1998 4Runner SR5 4WD
Goodyear Tracker Radials LT265/75R16
110,000 miles
Old 09-07-2006, 08:32 AM
  #127
KGSC68's Avatar
I have the same problem at about 60mph. I had a new set of tires put on and the trouble started. After 5 return visits and many words with the tire place, the mechanic took me back and showed me what he had found. The tires balanced out perfect on the machine but every wheel was out of round. I saw this with my own eyes and it wasnt obvious by just standing back and looking at the tire spin. As he spun the tire on the machine held the point of a scewdriver dead steady and pointed to the edge of the wheel where it meets the tire. He informed me that he has seen many Toyota Tacomas and 4Runners with this same problem
Old 09-07-2006, 08:59 AM
  #128
farmerj's Avatar
And when I was spinning tires on a daily basis, I saw it on Chevy's and Dodges and Fords and everything else on the road.
Now, if he were to take some paint stick and LIGHTLY let it hit on the face of the tire and spin, I would be partial to believing the guy. This will show you run-out a lot better. About the only thing he could really show you would be a bent rim.
Look at your wheel weights? How many are on it? More than one? A really big weight? Is there a gap between them?
If there is, have them break the bead and spin the tire on the rim. The balancing is more effected by the heavy spots on the rim and tire combined and you can change your weights needed to balance by rotating the tire on the rim.
If you look on a new tire. There should be a white spot on it. That spot should line up with the valve stem. I never did figure out why that is, I just know between rims and tire manufacturers they figured something out and that was it.
Old 10-18-2007, 10:03 AM
  #129
TopCat's Avatar
I've got the same problem on my 2000 extended Taco with my BFG Revos. They were super smooth on my '94 Ranger; swapped them to my Taco hoping for relief from the Goodyears. Wasn't the tires.
I'm going to have to try the crayon on the tires while mounted on the truck and see what the tread runout is. It's driving me to the point of trading it in... after putting another $2k into it so far.
I also experience a driveline vibration @ 38-46 MPH. Anybody have issues with U-joints in these vehicles?
- TopCat
Old 12-17-2007, 02:02 PM
  #130
Malcolm3.4's Avatar
I am having the same issues with my 02 sport. I had the same problems with my 00 Jeep Cherokee. I replaced the front calipers that were sticking sometimes and the vibration disappeared. Anyways, I will be changing my 02's calipers as soon as my braided brake lines come in. It is probably not rims and tires. Just changed mine on saturday from stock rims with 265/75/16 to 265/70/17 on brand new Ultra 160's. Still same vibration at 68-71 miles per hour.
I tried the whole rebalancing thing with my jeep to no avail. Started around 50,000, around 100,000 finally figured it out. 4Runner started vibrating around 75,000 miles with stock tires and no mods. Two sets of bfgs later still shaking like crazy.
BTW anyone know where I can get new front bearing cheap?
Old 12-17-2007, 02:58 PM
  #131
naksukow's Avatar
Jack up the front end. Grab 12 and 6 o'clock positions on the tires and shake back and forth. This will check the upper ball joints for excess movement.
Next grab 3 and 9 o'clock positions on the tires and shake back and forth. This will check for idler arm and pitman arm movement.
Good luck with your problem.
Old 12-17-2007, 10:22 PM
  #132
Man4God's Avatar
There really could be a million things going on here. I know that I have the same issues but mine start at a lower speed 25 on up. Its the low humming "wub wub" type sound that gets faster with more speed. I think my Pirelli Scorpions (came with truck) are the problem. I will check run out as well and see if the rims are the culprit.
I will also lube all the zerks in the drive shafts and transfer cases as well. If I have time I will do differentials too. Its just one thing at a time. And it's a pain in the ass too.
Old 12-18-2007, 09:54 AM
  #133
Ultraman V's Avatar
I bought a 96 Taco with a 3" lift and 33's and 170,000 on the clock. Right at 60mph she was rough as hell, 50 was smooth and 70 was smooth. I greased all the U-joints and also the slip yokes on both drive shafts. My 60 mph vibration is now gone. I've even fixed (fingers crossed) almost all of the dash rattles as well.
Lube those things up before the action.......
Old 12-18-2007, 09:59 AM
  #134
Man4God's Avatar
Originally Posted by Ultraman V
I bought a 96 Taco with a 3" lift and 33's and 170,000 on the clock. Right at 60mph she was rough as hell, 50 was smooth and 70 was smooth. I greased all the U-joints and also the slip yokes on both drive shafts. My 60 miles per hour vibration is now gone. I've even fixed (fingers crossed) almost all of the dash rattles as well.
That is GREAT news! My truck has 137K on it and no doubt it needs to be done anyway...I love it!
Old 12-18-2007, 06:15 PM
  #135
DoubleZero4x4's Avatar
Flat Spots
Your's definately sounds like a flat spot on the tires. Had the same problem with the wifes 4Runner. Replaced tires, smooth as silk.
Old 12-18-2007, 09:07 PM
  #136
Man4God's Avatar
Think Pirelli would road hazard them? Or otherwise warranty them?
kbpickens
10-02-2015 03:37 PM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
JPV
09-28-2015 03:15 PM
Odin
09-26-2015 06:56 PM
Quick Reply: Can worn out shocks/struts cause vibration above 65mph? HELP!
