Can too much oil in the engine show a code ?
Can too much oil in the engine show a code ?Iput about a 3/4 of a litre too much in the engine with my last oil change .After a long drive the check engine light appered .
Can't say much without knowing the code. Get it pulled by a nearby shop or by a friend with a OBDII scanner, then post it up here. Once you have the code, you can search it here and find the information you need. There is a posting on the site somewhere that lists all the codes and the associated error messages. Good luck.
Jnkml
07-06-2015 01:20 PM
