Can I move my lights like this? Advice? - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 03-20-2007, 01:42 PM   #1
04 Rocko Taco's Avatar
Okay guys, what I am trying to do is move my turn signals from the lower valence of my 04 D-Cab Taco, and put them in new mounts inside the parking light assembly outside the headlights. I have to find some way to have them on constant for parkinglights, and still blink when I hit the turn signals, and then I want to use the turn signal assemblies in the lower valence for what they look like they should be already, foglights. I want to put a set of H3 bulbs down there...what do you guys think? I know its a confusing set of ideas, so here is a picture. I know how YT people love Pictures.
Thanks for any advice, both technical, electrical, or any other kind.
EDIT, okay you cannot read the blue writing.... I'll fix that and repost, for now...you get the idea...
Okay here is the Edit Picture, I'll leave the original in for ...laziness.
04 Rocko Taco is offline   Reply With Quote
Old 03-20-2007, 01:43 PM   #2
WATRD's Avatar
Yes. There are several ways to do exactly that. You can use a two way bulb in one mount or two bulbs or you can go with LED's for either/both. There are write ups on how to do that scattered around the net. If you can't find one here, then I know there are several on TTORA.
WATRD is offline   Reply With Quote
Old 03-20-2007, 02:16 PM   #3
Thanks Rob!
Old 03-20-2007, 02:50 PM   #4
Elton's Avatar
guess you will need some 1157 sockets and some cutting to make them fit
Elton is offline   Reply With Quote
Old 03-20-2007, 02:51 PM   #5
CJM
CJM's Avatar
I dunno about the rest of ya'll but I would just take the entire bulbs and wiring and route it into the parking lights and switch out for amber bulbs..
CJM is offline   Reply With Quote
Old 03-20-2007, 02:56 PM   #6
Elton's Avatar
i did this to my bumper lights take that idea and move it up to the corner
/f131/makeing-your-turn-signals-light-up-110242/
Old 03-20-2007, 03:10 PM   #7
aviator's Avatar
Cool idea Chris
As people have already suggested here changing the existing socket to an 1157 type would probably be the easiest way just hook what would normally have been the brake/turnsignal lead up to the ungrounded wire of the turn signal harness and you're in business.
As for using the existing turnsignal as a fog light you might have have some spread/pattern issues just use a yellow lamp and you'll be good for colour though.
One other thing you need to check the traffic code in your area there might be some restrictions regarding visibility of the turn signal your corners are partially blocked by the bull bar.
Cheers avaitor
edit: another idea the uk spec surfs have a turn signal up in the corner there. where we have a flat orange reflector insert they have a raised lens with a lamp behind.
Check some of the rigs on www.hiluxsurf.co.uk the people there are very friendly and might even be able to hook you up with parts if you want to that route. their site was down again the other day though so I don't know if its working right now.
edi edit: the site is up again if you want to go this route there is a guy there named Jotto is parting out a surf [runner] and might have the parts you need
aviator is offline   Reply With Quote
Old 03-20-2007, 03:12 PM   #8
drguitarum2005's Avatar
Location: Houston (home), Atlanta (school), Cincinnati (work)
shoot chris, everyone with an aftermarket bumper on a taco does this basically! just an 1157 socket and 1157 dual-filament bulb. no crazy wiring needed. the part that took me the longest was cutting out bigger holes for the socket and waiting for the epoxy and silicon to dry for new mounts. its super easy!
drguitarum2005 is offline   Reply With Quote
Old 03-20-2007, 03:21 PM   #9
drafn's Avatar
heres the write up i was going to use to do mine just never got around to it.
http://www.4x4wire.com/toyota/tech/tacoma_turn_signal/
drafn is offline   Reply With Quote
Old 03-20-2007, 03:25 PM   #10
881stGenRunner's Avatar
/f131/how-do-i-make-my-park-lights-double-blinkers-104633/
here is another thread that UKMyers made there are a few other links in there.
881stGenRunner is offline   Reply With Quote
Old 03-20-2007, 06:48 PM   #11
Thanks guys!!! Looks like this should be EASY.
Old 09-06-2007, 07:56 PM   #12
mwilliam13's Avatar
Turning signals, parking lights...
What actually came of this mod?? I have a similar need, but on a 86 4runner. I found a mod idea on Roger Brown's website, but am not certain I want to do it... I was hoping to just run the stock turning bulb & harness into a hole I would bore into the back panel of the parking light assembly. Do you have any feedback on what you did?
Bill M.
mwilliam13 is offline   Reply With Quote
Old 09-07-2007, 08:16 AM   #13
Rock Slide's Avatar
mwilliam13,
I did what Chris is describing on my old '86 4Runner. I installed an aftermarket front bumper, so I lost the turn signals in the lower valance. All I did was re-route the turn signal wire from the lower valance, and stuck it into the side maker light hole. Granted, I did not use my running lights anymore, but I did have turn signals instead.
Rock Slide is offline   Reply With Quote
Old 09-07-2007, 10:27 PM   #14
mwilliam13's Avatar
Lights, lamps and stuff
So, I removed the parking lamp assemblies and removed the turning lamps from the valance assemblies as well. I went to the auto parts store, and found a pair of Calterm 08574 signal tail lamp sockets originally for a GM. I also bought the corresponding 1157 bulbs for them. It seems reasonable to widen the original hole for the running lamp a bit, and mount this socket in about half way, that is if I have enough clearance between the back of the housing and the body of the truck. Will probably hack into it this weekend to find out. Also, I am entertaining the idea of finding a taillight assembly donated from another yota in the bone yard. It may work... may need to mod a bit! I will post images of success or failure.
Nervous, but will commit once I start it.
Old 09-07-2007, 11:03 PM   #15
KU_MechE's Avatar
here is my thread with your concept. It was not well received and i could have executed it better, but I mounted my blinker bulb in my corner light housing. I also have clear corners, but IIRC the corner bulbs are 5W and the blinker bulbs are 25W. Even though they are in the same housing (just drilled a hole and stuck them in) the blinking is much brighter and very noticable.
http://www.yotatech.com/f2/new-lights-99-w-pics-109249/
KU_MechE is offline   Reply With Quote
Icentropy's $400 4runner build icentropy 86-95 Trucks & 4Runners 14 10-22-2016 10:24 PM
22re complete exhaust: please advise tj884Rdlx Newbie Tech Section 25 08-28-2015 01:04 PM
91 22RE Should my Oil Pressure Warning light come on when disconnected? Odin 86-95 Trucks & 4Runners 8 07-15-2015 10:28 PM
Leaking Rear Tranny Seal and Top Tranny Gasket Iceman4193 86-95 Trucks & 4Runners 3 07-15-2015 05:48 PM
2000 camry wont start Huntingtruckcletus Other Makes Cars/Trucks 0 07-08-2015 06:26 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
