| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
__________________
2000 toyota 4 runner: fr & rr arb lockers, sonoransteel front lift, OME HD's, bridgestone 285/75/16 duelers, diff-drop, sliders stubbs herculined, panhard drop,tjm-t15, warn m-8000, power tank, sonoran steel 1" bl rear bumper, 1" rb bl, synth winch line, alum fairlead |
#2 (permalink) |
Well, if you now have another inch of lift, you can uncrank the SAW's until your tires rub again.
#3 (permalink) |
It depends on what you are trying to accomplish. If you just want to fit larger tires, then do what Flygtenstein said. If you are trying to gain ground clearance, then the body lift won't help you any and by lowering the SAWs you will lower your clearance.
__________________
- Brad 2000 4Runner SR5 4x4 5spd 3" Revtek spacer, ARB RD-90 front | 3.5" Downey coils, E-locker rear | 285/75 16 BFG M/T | TJM T-17 | RB Sliderz | 1.5" RB BL | BudBuilt skid | 4.30s | SS Rear Bumper onetruth |
#4 (permalink) |
ok I don't understand something here .. how does putting a body lift on affect your cv angles ... I thought the axles went from the frame to the wheel.
Or are the attached to the body?
__________________
Experience is a hard teacher because she gives the test first, and the lesson afterwards. <-- the artist formerly known as sdastg1 |
#5 (permalink) |
Hes saying he is going to add a 1" BL to compensate for lowering the saws. Then He will still have the same amount of clearance at the fender for his tires with less stress on the cv's due to the lesser angle of them.
__________________
David Anderson Hit me up on AIM at Dbikeman85(im always on) 98 4runner SR5 w/99bumper 99 scoop hood and 99 headlights Clarion VRX935VD 7" flip out, Excessive Amperage 200amp alt. Kicker Kx1200.1 amp, Eclipse Titanium 12 Stinger 0 gauge and stinger cap. Xstatic Batcap Jaos Aero Billet grille Jason B clears in the corners and bumpers Clear Tailights Magnaflow 18" with 3" Magnaflow tip |
#6 (permalink) |
Thanks for the input. Im w/ the bl Im trying to eliminate the slight rubbing I currently have. But like dbikeman said if I can eliminate the rubbing and still lower the SAWs (thus imp cv ang) w/ the bl than Im golden
Thanks again for the input. Anyone whos done what Im thinking about feel free to chime in. AG
__________________
#7 (permalink) |
why not just keep the SAWs at 3", get a 1" diff drop, and do the body lift. Then you get the best of both worlds and not sacrifice your CV either.
__________________
#8 (permalink) |
I'd do the body lift and drop the saws, even with the diff drop the cv angles aren't great and I still got some grease seepage. The closer you are to stock, the longer your cv's will last. Also, keeping less tension on the SAWS will soften the ride up a bit as well. You could also install the Revtek Top Out Spacer that will also gain you some lift and drop the SAWS even further. This will make the suspension even flexier, but won't do jack for the CV's.
__________________
-David '98 4Runner: SAW/OME lift, TJM bumper, Warn M8000 winch, Hayden tranny cooler, Trail Carnage front and belly skid plates, PIAA fogs, Rock lights, 33" MT's on Tech1 Rockcrawler rims, Lars sway bar discos, Sonoran bumpstops and rear bumper, RB 1" body lift, Daystar front bumpstops '73 FJ40: 327 SBC, York, Dual Batteries, custom tire carrier, Corbeau Baja SS bucket seats, Bestop top. TLCA#14428 |
#9 (permalink) |
yes i have. i dropped my suspension to 2" after my 1" body lift.
i am actually thinking about dropping it another 1".
__________________
Ryan New: 2008 4Runner Sport. Mild, not wild. Old: 2000 4Runner 305s, Locker, TJM, Warn, Skids, Sliders, SC |
#10 (permalink) |
Thanks Dawgs,
Ive used your (and Schaefers) site for alot of info, if I can drop my saws almost 1" w/ a bl I think its worth it. I know you got a roger brown 1" did you need the steering spacer and radiator reloc? and what kit did you order? I hope you eventually get SS's approval. Thanks AG
__________________
#11 (permalink) |
i did get the steering spacer but no radiator bracket.
i got ultimate blocks and standard hardware i believe.
__________________
#12 (permalink) |
Thanks again,
Good luck on the approval, It might help if you bought something from him AG
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Hilux w/ 3" BL & 6.5" SL | Geographeen | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 07-11-2007 04:48 PM |
| Thinking of "remodeling" my lower valance | chrishf12 | The Fab Shop | 27 | 06-01-2007 02:19 PM |
| 3" BL. Need IMMEDIATE Help. | 04 Rocko Taco | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 09-01-2006 11:10 AM |
| Spidertrax Lower Control Arms "updated" | sschaefer3 | Offroad Tech | 7 | 09-30-2003 08:30 AM |
| post your pics... 33s and 1"-2"BL | jacksonpt | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 09-11-2003 06:59 PM |
